Question about Emerson CKS2237 Clock Radio
Time is wrong
The time is about 20 minutes ahead... I used to put all my clocks at the "radio" time, until I realized that I was late everywhere!!! LOL! And realized that the clock is ahead of its time! Can it be fixed Doc? Stephane scaiveau@hotmail.com
  • ladibug340 May 22, 2008
    I have:
    SN
    407030070PH
    Model #
    CKS2237
    My clock constantly
    gains time - sometimes as much as 15 or 20 mins. I have moved it near a window and
    this did not fix the problem. How would you suggest this problem be
    fixed?
    Blessings,
    Brenda.
    Novelist:
    Champion:
  • 277 Answers
Sure. p.7 in the user guide: http://www.sonigem.com/uploaded_files/manual_archive/CKS2237Ceng.pdf
Posted on Dec 11, 2005
How do I set my clock back an hour? It is the wrong time. My daughter set it ahead not realizing that it would change itself for daylight saving time.
Most digital clocks do not have the ability to move backwards. It is simply a matter of moving the clock hours forward 23 hours and you will be right back where you want to be. I hope this helps.
Mar 11, 2015 | Audio Players & Recorders
My Howard miller clock chimes one hour ahead . It
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Oct 07, 2014 | Home
Set tme 4837 clock radio
I have the same clock radio and I found out that you have to hold down the button and run through the times. The hour will change with the minutes. It goes pretty fast once you hold down the button, so I stop when I get close (like within 20 minutes of where I need it to be) and then click it one minute at a time until it's at the right time.
Jun 09, 2012 | GE 7-4837 Clock Radio
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
Sony IFC-218 clock radio runs 8-9 minutes fast
Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
Don't expect this clock to set the time by itself. It is not an atomic clock.
Nov 29, 2011 | Sony Audio Players & Recorders
My emerson didn't change the time. I'm so
If it's an older clock it's set on the old (later) daylight saving time schedule, and there's nothing you can do to modify that. Your choices are to set it manually now, realizing that it will "spring ahead" again in a week or two, or replace it with a new clock that's programmed for the new schedule.
Bill B
Mar 15, 2010 | Emerson (B0002HKS0S) Clock Radio
My clock radio wont keep the time once I set it the clock advances 2 to 3 hours ahead
I took the back up battery out and unplugged the unit for about 20 minutes before powering the clock back up. Once I powered the clock up I re-inserted the backup battery.
Jan 17, 2010 | Emerson Smartset Clock Radio
CANNOT GET RADIO TIMECLOCK MOVED FORWARD BY ONE HOUR.
If yours is aipine cde 9841 then
Set the display to time by pressing the tittle button. once time is displayed, press tittle button and hold until the time starts blinking. now adjust hour using arrow keys. now press mode once and use arrow keys for adjusting minutes. press mode again. now the time is set.
Alex Victor
Mar 28, 2009 | Alpine CDE-9841 CD Player
Brookstone smart set alarm clock. It is about 20minutes ahead
I've noticed that manually setting the clock forward or back by any number of minutes, results in the same time offset being displayed after unplugging - plugging back in. So, if it's 9pm and you set if 5 minutes fast (9:05pm). Then unplug it and plug it back in 30 minutes later (9:30pm), the clock will maintain your setting of 5 minutes ahead of the actual time (9:35).
I like to set my clocks 5 minutes fast, just to make me always think I'm running a bit late (sure, maybe I'm a bit crazy). But this "sticky" manual setting is kind of a nice feature in my opinion. I'm wondering if it's not intentional?
Anyway, just manually set it back to the real time, and it sho
Feb 18, 2009 | Brookstone SmartSet Alarm Clock
Resetting clock
Press the SET button until you cycle through the alarms and the Colons on the time start to flash. use the right and left arrows from the CD buttons to adjust time; After time is set; press the SET button. Be careful to not fat finger and hit the CD button when pressing the SET buttons. That will turn on the AWFUL NAP timer. That's another headache.
. Stop the Nap alarm Press NAP to start NAP flashing. Press and hold NAP to cancel the nap setting. If this does not work; try again. It seems to take me a time or 2 to get it to work.
Feb 04, 2008 | GE 74801 Clock Radio
Emerson CKS2237 Clock Radio Logo
270 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
