Question about Ego MD230/F (1 GB) 256 MB MP3 Player
Warning - No WAV File!
I erased all the archives of my Ego md230. I do not obtain more to use the function to record voice. It appears the message "No WAV file". What I must make? ThankĀ“s, Lima.
SOURCE: error in files
hi i download songs on my mp3 but it vanised
Posted on Jan 11, 2008
0 characters
1 Points
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Jun 26, 2011 | MSI MEGA Stick (256 MB) MP3 Player
I had recorded voice in PHILIPS (SAXX )which have been stored int the Recordings Library. But when i want to hear, i find a reply the " file format not supported". What to do to hear the voice...
If you connect your player to the PC and select your device in Windows Explorer you should find a "Voice" folder that contains your recordings. The files are named as voicexxx.wav and you can simply copy and paste them to the PC.
If you have problem with this and want to get additional help please define the exact type of your player because almost all the types of gogear are SAxx .
Thanks
gylacz
Apr 29, 2011 | MP3 & Digital Media Players
I would like yoknow what format do i need to download a video to my vl-567
Supports MP3 / AMV / WMA / WAV / JPG / TXT
----------------------------------------------------------------------------------------------------------------------------------------Model: VL-567k / VL577k
  • Built-in Memory: 4GB Flash Memory
  • Supported Formats: MP3, AMV, WMA, WAV, JPG, TXT
  • FM Tuner: Built In, Radio/Auto Scan/Store/Erase
  • Lyrics: Yes. Supports .lrc format.
  • Data Retention: 10 Years
  • Voice Recorder: 200 Hours with recording rate of 8khz
  • Voice Mode: Selected content repeat function (A-B mode)
  • Weight: 1.3 oz.
  • Dimensions: 3.6in x 1.6in x .34in
  • LCD: 1.8" Anti-Scratch True Color 65,000 color.
  • Equalizer: Natural, Rock, Pop, Classical, Soft, Jazz, DBB
  • Repeat Mode: Normal, Repeat Once, Repeat All, Repeat Folder, Random, Intro
  • Battery: Rechargeable battery, ~3-5 hours playing time when fully charged, ~10 hours charging time through USB port
  • File Transfer Speed: Reading (700 kb/s), Writing (400 kb/s)
  • SNR: 85db
  • Output Power: 5mW+5mW
  • Output Range of Frequency: 20Hz-20KHz
  • PC Interface: USB 2.0
  • System Requirements:
    • Windows 98SE/ME/2000/XP
    • 166 mhz cpu or faster
    • 32mb of RAM
    • 20mb available disk space
    • Available powered USB port
Dec 26, 2010 | Visual Land VL-567K Digital Media Player
Can I save a WAV file to MP3 format
There is a free program called Media Monkey - it will convert WAV format to Mp3 (actually, it will convert any non-protected music file type - it's very dynamic). It may take a while to figure out how to do the first one, but it will get easier after that.
First, you have to plug the Thomson in to your computer, double-click "My Computer," and then double-click the icon of the Thomson. There should be a folder called "Voice or "REC". If it doesn't show up, select in the window: Tools --> Folder Options --> View --> select Show Hidden Files and folders. Now the right folder should show up. Then, drag the WAV recording to your desktop (or your "My Music" fodler - whichever works best for you), and the computer should make a copy of the WAV recording onto your computer.
Now open up Media Monkey and it should, after several minutes find all music files on your computer, including the WAV recording. Then right-click the WAV recording, and it should have an option to covnert the file type - convert to mp3, and you're done.
-Tha Mp3 Doctor
Mar 22, 2009 | Thomson Lyra PDP2842U MP3 Player
Need to download from mp3 player to a disc, is it possible
First, you will have to hook your Sansa to your computer. Then, you will need to double-click My Computer, double-click the icon or drive letter that corresponds to your Sansa, and then open the Voice folder. Find the recording that you want to back up and drag it to your desktop or other temporary location on your computer. Then you will most likely want to convert the recorded WAV file to mp3 format using Media Monkey or some other free conversion tool. Then use disc-burning software like Roxio or Nero to burn the converted file to CD. Have fun!
-Tha Mp3 Doctor
Dec 30, 2008 | SanDisk Sansa e250 MP3 Player
T sonic 630 4GB recording has only bells 30 secs no voice!
The system should support the .wav format. install latest version of media player
Dec 23, 2008 | Transcend T SONIC 630 MP3 Player
Need to cnveert wav voice recordings to mp3 om sansa view
Have you tried Audacity? It's free opensource sound editing software. Search Google for it or try downloading it at audacity dot sourceforge dot net. (You do have to install an mp3 encoder! but those are also free, and the Audacity site tells how to do this), Then you just import your wav file, and export it as an mp3
Dec 15, 2008 | SanDisk Sansa e250 MP3 Player
TIME FOR VOICE RECORDER IN 512MB
Not very much. It depends on how many songs are already in the player. The problem is that the recordings are made in WAV format, and WAV format takes up MUCH more space than an mp3 file. If you had no other songs on the player, I would say an hour maximum - maybe much less.
Aug 21, 2008 | Philips GoGear SA178 MP3 Player
MyMusix MP3 Player
All documentation for this product is available at www.mymusix.com
Voice record
Use the built-in microphone to record voice in the voice mode.
1) Press "Rec" button to begin recording
2) Press "Rec" button again to stop recording
3) Press " play/pause" to pause or resume recording
4) Recorded files are stored as default files VXXX.WAV, XXX numbered from 001
-Tha Mp3 Doctor
Apr 03, 2008 | MyMusix PD-6030 MP3 Player
Error in files
i guess that u still have warranty on the md if so take it 4 a goodcare windman
Jan 30, 2006 | Ego MD230/F (1 GB) 256 MB MP3 Player
Ego MD230/F (1 GB) 256 MB MP3 Player Logo
41 people viewed this question
Top Ego MP3 & Digital Media Players Experts
Walesarumi
Walesarumi
Are you an Ego MP3 and Digital Media Player Expert? Answer questions, earn points and help others
