Question about iRiver E10 Digital Media Player
E10 firmware 1.04 upgrade
Ever since i upgraded t v1.04 my e10 regularly freezes, doesn't sync with my computer well or freezes my computer when i plug the e10 in. How can i downgrade to v1.02 asi never had any problems before the upgrade?
thanks reece
4 Suggested Answers
  • 4 Answers
SOURCE: E10 Firmware
use i river3 or 2 to initialize it
iriver3 tools> portable device> disk initialization.
iriver2 Option> portable device initialization.
This should work.
If not maybe try to format it.
cheers twenty
Posted on Mar 28, 2008
SOURCE: I upgraded firmware on new iriver e100
Let the power run out. the same thing happened to me. unfortunately the firmware upgrade didn't take effect but i'm about to do it again now
Posted on Dec 29, 2008
braydenx3
  • 32 Answers
SOURCE: E100 8Gb froze after firmware upgrading
your irivers firmare is lets just say  um broken and is unreadable
sorry but youll have to send it back to the factory
Posted on Mar 04, 2009
SmartAviator
  • 449 Answers
SOURCE: not possible actualization firmware E10
Device may require on-line firmware upgrade. Try updating firmware while connected to Internet.
Posted on Jul 15, 2009
PLAYER UPDATE REQUIERD !!! PLEASE REFER TO THE MANUAL
All online support for iRiver players is on next site:
http://www.iriverinc.com/lounge/loungeList.asp
note
If you enter an unreadable page: return to / start from the support site above.
Download of the manual
select a category: Manual
select a product: E10
click GO
select: User Manual of E10
Click the zip file in the language you prefer: English.zip for English .
Unzip the file after the download with Winzip or Winrar, to see the PDF file that can be read with Adobe Reader.
Upgrade using iRiver PLUS3 = Download and run iplus3.exe for matching the software on your computer and the firmware on the player
In page top of the support site: click Plus3
Click the Overview | Function | Download to see what Plus3 is and how it works.
Click Download irver PLUS3 to directly start the installation of this program onto your computer
Update the firmware = Download the firmware and run the firmware updater
for putting new firmware into the player
select a category: Firmware
click GO
select: New Firmware of E10
Download the updater zip file
Unzip the firmware updater with Winzip or Winrar and run the execute file to start iriver Firmware Updater: follow the steps.
After a firmware update always run the Plus3 upgrade: to have the correct software on your computer that communicates with the player's
firmware
Aug 01, 2010 | iRiver E10 Digital Media Player
Upgrade Linksys WRT54G2 firmware failed.
there are 3 variants of the WRT54G2 , v1, v3 and v5 ensure that you choose the right firmware for the variant(its on the bottom of the router)
Go to the US site as this has more uptodate versions of the firmware.
For example v1 in the UK is at 1.0.0.0 dated 2008
v1 from the US site is 1.0.0.4 dated 2009
Jan 25, 2010 | Linksys WRT54G2 Wireless Router
Not possible actualization firmware E10
Jul 15, 2009 | iRiver E10 Digital Media Player
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
http://kbserver.netgear.com/products/WPN824.asp
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at http://192.168.1.1 or http://192.168.0.1 (or www.routerlogin.net ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at http://192.168.1.1and check the firmware version.
***DONOT UPGRADE FIRMWARE USING A WIRELESS LAPTOP/PC
Oct 26, 2008 | Computers & Internet
Sansa e250
First, the player has to be reset - see your manual for details
Second, if it freezes after reset, then your firmware has to be upgraded - the upgrade was at the Sandisk website, but I've heard rumors that they have taken it down - which will require you to make a phone call to Sandisk
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
Wont work
Sounds like a firmware upgrade is needed. If an Mp3 player freezes one time only, you can simply reset it. But if it is continually freezing on you, then you either need a firmware upgrade or you are having an actual hardware issue.
-Tha Mp3 Doctor
Jun 06, 2008 | SanDisk Sansa c200 MP3 Player
Wont work
-Tha Mp3 Doctor
PLEASE HELP ME
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 20, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250
Go ahead and do this, in case the DB is corrupted:
-Tha Mp3 Doctor
Apr 08, 2008 | SanDisk Sansa e250 MP3 Player
MY sansa connect 4gp crashes my computer
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
iRiver E10 Digital Media Player Logo
1,002 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
