Question about AKG SolidTube Professional Microphone
Lots of white noise and crackles, and intermittent problems.
I have had a serious issue for a long time with my AKG Solidtube microphone where I get tons of noise and crackles. It sounds like I'm standing out side and galeforce winds are blowing in my ear. This is definatelt a fault with and other equipment as I have used several other mics through the same channel, on the same desk and they have all been fine. I have even replaced the cable but the promlems still remain. Any ideas?
Kind Regards
Ross
Check and make sure on the back of the power supply that it is set up for your local voltage(120/240)
Posted on Nov 28, 2008
Need help repairing N-soundtube PSU for AKG Mic
Define what you call the transformer. The microphone has a power supply in a separate enclosure. Usually the output has 7 pins to connect to the cable to the mic. First you need to verify that the cable is good. With a multimeter, check continuity of each end of each pin. If one pin has no connection, the replace the cabble and your problem will go away. Try this first, then if needed we'll talk about the power supply.
Roy
Walker Labs
Aug 10, 2014 | AKG SolidTube Professional Microphone
How do I solve the problem of a crackly switch?
It has dust or oxide inside. Go to Radio Shack and pick up a can of "Tuner Cleaner" or "Contact Cleaner". Using the tube that comes with the can, spray the switch liberally, trying to get some of the spray down inside the switch. While still dripping wet, work the switch back & forth several times. Let it dry out & use it.
If that's not enough... the mike will need to be opened up to gain better access inside the switch with your spray. No need to unsolder anything, you just need to get that spray inside the switch.
Don't use anything except "tuner cleaner" or "contact cleaner" for the purpose. Don't use WD40, don't use silicone spray, don't experiment. Let's get your mike working... and only tuner cleaner or contact cleaner is known to do that.
Jul 26, 2014 | AKG SolidTube Professional Microphone
Akg repair
spray it with contact cleaner or wd40 and work it back and forth a few times
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
When I turn on my SolidTube and let it warm up for a couple of minutes it sounds great. After like 20-30 minutes or so the volume fades. You can still hear it, but barely audible. I've tried put put in a...
I would be inclined check your +48v phantom power supply to make sure the correct voltage is coming out and to check your cable. Failing that, if you have changed the tube once I'd be inclined to contact AKG Directly via email to find a service center or get furthur advice.
Jan 16, 2011 | AKG SolidTube Professional Microphone
Crackling noise and low volume
If the mic is a condensor you would need to have phantom power, or it will not work. Use a small mixer or externat power supply. We here at Pro Line Music Have small mixers that have phantom power. 215-736-8055
Dec 26, 2009 | AKG Perception 120 Microphone
Excessive line crackling noise
The service manual is at www.akg.com/mediendatenbank2/psfile/datei/19/C4194055d1fa264a7.pdf. You will have to replace the wiring that goes to the cartridge through the gooseneck.
May 25, 2009 | AKG C419L Professional Microphone
AKG 414 crackle
Had the same problem. Check the ground (earth) is attached properly to the mic. This will cause the signal to be interrupted and can also cause a phasing problem. A lot of techs don't check that when you send them for repair
Nov 12, 2008 | Audio Players & Recorders
Akg mic buzzing
constant unrelenting hum?
check the fuse housing and make sure it is setup for your local voltage(120/240)
Jul 23, 2008 | AKG SolidTube Professional Microphone
Problem With the Power Supply for AKG SolidTube
Well your obviously drawing too much current.
The other given is that it takes time. This means its a thermal problem. Temperature goes up and current goes up with it.
Look for plastic or cold solder joints. A plastic joint is dull and brittle also look for islands in the solder joint where the solder
is actually disconnected from the part.
Components like regulators also can go thermal.
Look for discoloration.
Get the unit to act up and carefully spray freeze mist at
various locations and you may agrivate it.
Problem may be in MIC and not SUPPLY.
Good Luck
Oct 27, 2007 | AKG SolidTube Professional Microphone
AKG SolidTube Professional Microphone Logo
447 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
