Setting Datagrid runtime in Visual Basic
I have set all the column by Data is not appearing in Grid. Please help me if any one
Code :
Set DataGrid1.DataSource = rs
DataGrid1.Columns(0).Caption = "Ledger Name"
DataGrid1.Columns(0).Width = 1200
DataGrid1.Columns(0).DataField = "rs.ledger"
DataGrid1.Columns(1).Caption = "Amount"
DataGrid1.Columns(1).DataField = "rs.clamt"
  • 32 Answers
Don't use Data Controls
Don't use binding
Use pure ADO code instead of the above
Use the flexgrid (or the free SGrid2) instead
If you are using VB6, get help in these two forums-
I am in the VB6 one often, so I will chip in to help
Posted on Jan 16, 2017
  • 363 Answers
This website can help you
They serve good high efficiency, safe and convenient transaction, you can go to experience
The price is certainly the cheapest
There is also often very affordable activity
Posted on Jan 05, 2017
    New Friend:
    Problem Solver:
  • 17 Answers
I have found a C# Data Grid Tutorial for you as reference. It is easy to understand.
Posted on Apr 24, 2014
I think you are missing this at the end:
Posted on Sep 06, 2008
How to build a datagrid with master detail relationship in php
I also don't have much experience in the PHP, however, I think you can try some convenient datagrid like the UI GridView Control for WinForms I've heard before.
Nov 14, 2013 | The PHP Group PHP
I have a visual basic program in which i have to display the record from access table by using connection of adodc.and then select record from datagrid will display in another form. plz reply as soon as...
hi,  you may visit this site and download all free visual basic source codes with tutorials..  One of the source code will solve your problem.    However their paid Visual basic source codes will most powerful.    As I am total deaf and no source to communicate others... I want to share the  payment source codes with tutorials from  Are you ready... If you download the  source codes with tutorials (only Fee for it) I will share with you.
Apr 08, 2009 | Microsoft Visual Basic Enterprise Edition...
How to shortlist combobox items at runtime ?
Each time a letter is typed by your user, re-query from the 50 and return ONLY those meeting what your user typed. Clear and re-populate the ComboBox. Also - Set the Sorted property to True!
Mar 30, 2009 | Microsoft Visual Basic 6.0 for PC
Exe file created not running on other pc.
Hello narensg
In order to be able to run a program (EXE) in a computer, that computer must have Visual Basic RUNTIME MODULES.
please tell your friend to install this runtime modules:
after installing this package, he will be able to run your program.
Kind regards,
Jerry H.
Feb 25, 2009 | Microsoft Visual Basic 6.0 for PC
I have a runtime error 9 subscript out of range, when i try to open a program
  1. Start the Visual Basic Editor (press ALT+F11).
  2. If Project Explorer is not visible, press CTRL+R to activate Project Explorer.
  3. Click to select the Visual Basic project that contains the module sheet that you want to copy.
  4. On the Tools menu, click References. Click to select the Microsoft Visual Basic for Applications Extensibility 5.3 check box, and then click OK.
  5. Click Module on the Insert menu.
  6. Type the following code into the module sheet: Sub CopyModule() Dim CodeLines As String Dim ModuleToCopy As VBComponent Dim NewModule As VBComponent ' Set a variable to the module to copy. ' Note: This assumes that the name of the module to copy is ' "module2". Replace "Module2" with the name of the module to copy. Set ModuleToCopy = _ Application.VBE.ActiveVBProject.VBComponents("module2") ' Get the Visual Basic code from the module. CodeLines = ModuleToCopy.CodeModule.Lines _ (1, ModuleToCopy.CodeModule.CountOfLines) ' Create a module sheet in another workbook. ' Note: You must refer to the name of the Visual Basic project. By ' default, the name of all new projects is "VBAProject". You may want ' to rename the project to which you are copying the contents of the ' module sheet. Set NewModule = Application.VBE.VBProjects("VBAProject") _ .VBComponents.Add(vbext_ct_StdModule) ' Add the Visual Basic code to the new module. NewModule.CodeModule.AddFromString CodeLines ' Rename the new module to the name of the previous module. NewModule.Name = ModuleToCopy.Name End Sub
  7. Run the CopyModule procedure.
Samson Ved
Dec 05, 2008 | Computers & Internet
C# datagrids
Follow these steps :-
1. Create a connection.
2. Fire the select query and fill the records in the dataset.
3. Bind the dataset with the grid.
Jun 20, 2008 | Microsoft AccRepair DS2 2004 for Fr...
Howto load data to datagrid using visual basic 2005 and sql 200
May I suggest providing us with the programming language enviroment, which you're using, as in, Visual Basic or something, that way, I think it would be easier for the experts to give you an answer.
Here is a helpful link about Databases, but it's for Visual Basic Express Edition 2008
The best of luck with your project.
Mar 19, 2008 | Computers & Internet
Hi All I have a Data-grid with 3 columns. One is Text Name, second is Image which denotes Offline/Online User Status. Third Image Denotes Blocked/UnBlocked User Status. Now, I want to change Image on Click. If User1 wants to leaves the chat, Then he clicks on Image in front of his name. Here the images should be changed. And a function userOffline should be called. The function is called on Click but Image does not change. If I try to change the image it changes all images in the Column of all users. Can any one help
Sep 25, 2007 | Macromedia Flash MX
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
