Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Ariston AVXD109 Error Message H20
Hi we get the H20 error message on our ariston front loading washing machine. The manual says to check the water inlet hose, both for connection and for a bend, that the water is not turned on or that there is insufficient water pressure. We have checked all these things and they seem fine. Any other ideas?
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Posted on Jun 13, 2008
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
futureloginn
  • 734 Answers
SOURCE: ariston dishwasher
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely
replace it. It's usually located behind the lower access panel on the left or right side. It's the device
with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two
wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor."
Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills
the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised
position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Dec 12, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
HOW TO FIX O9 ERROR CODE?
F09: Machine Setup Error Found (AWD12)
Setup error or incompatible EEPROM
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
Reflash EEPROM
Check electronic controller
Dado
Sep 09, 2014 | Ariston Technologies Ariston AWD12 Front...
My ariston 125washing machine is flushing H2O on the scrim
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The hose is bent.
Dado
Ariston washing 125 is flushing h2o on the screen
displayed).
• The hose is bent.
Dado
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
displayed).
• The hose is bent.
Dado
May 24, 2014 | Ariston Technologies Washing Machines
Error code h20
displayed).
• The hose is bent.
Dado
Mar 26, 2014 | Ariston Technologies AW 129 NA Washer With...
Ariston h20 errors
displayed).
• The hose is bent.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston ARF 105 H2O error!
I had this issue also and it was because I started the machine and had not turned on the water to it. However, it cleared when I unplugged the power cord, waited about ten seconds, then plugged it back in. I guess they need a "reboot" once in awhile, like a computer - at least mine did. Hope this works for you, too.
Nov 05, 2013 | Ariston Technologies Washing Machines
Error messages on my Ariston AVXD109
displayed).
• The hose is bent.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
1,757 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
