Question about KEIO PS2 Optical Scroll Mouse
Erratic mouse behavior or my mouse has a mind of it's own
KEIO optical mouse m/n p816 driver version:5.1.2600.0 Microsoft 2001 system: AMD 2000xp+ 1gig ram 130 gig hd WindowsXP home SP2 recently updated dvd burner cdrw Nvidia gforce 5200 video card My Mouse suddenly started behaving erractically. Sometimes it just wonders around the screen at random in an erratic zigzag fashion other times it will zip across the screen in any direction. If I lift the mouse off of the desk to reposition it the pointer almost always shoots to the bottom right corner of the screen. It is also a wheel mouse and in some webpages when I am scrolling down the page when I stop to read something suddenly it scrolls very fast towards the bottom of the screen. I primarily play Everquest on this machine and the mouse does the same things when playing the game. I have removed and reinstalled the mouse driver several times to no avail. I have changed to an older ball mouse, to a different optical mouse and tried several other ideas that folks on other forums have posted about. This is the second time I have had this trouble. I don't remember what fixed it before, but I thought it was simply reloading the mouse driver. I havn't tried wiping the harddrive and totally reloading everything yet But I might.. someone posted in another forum that they did and it fixed things for a short time. I have ran two or three spyware programs as well as a couple virus probrams. (detection programs that is) My system seems to be clean from those annoyances. Any ideas? Thanks, Core
  • Anonymous Apr 28, 2008
    I had a similar problem with an optical mouse that moved on its own accord, usually upwards and to the left when left stationary. When moving by hand, it was also erratic the pointer not following hand movement.
    I changed the mouse pad and now use a course brown paper similar to newsprint and the problem has ceased. Amazing.
GO TO REGISTRY EDIT, FIND HKEY_CONTROLPANEL\MOUSE.
DELETE THE KEYS THEN RESTART WINDOWS.
WINDOWS WILL REBUILD THE KEYS.
IT MAY BE THAT YOUR REG KEY IS CORRUPTED.
Posted on Mar 13, 2008
If the mouse is optical, check the surface you're using it on. There may be some reflective property causing the trouble. If you have a laptop with a touch-pad, the outer area of the touch-pad may be causing the problem. Check for the build up of debris around the touch-pad border (under the plastics).
Posted on Apr 06, 2008
Try a new mousepad. the lazer reads even the fibers of mouse pads. even if it feels clean, it might be picking up on that.
Posted on Jun 02, 2007
SOURCE:
How to turn on the microsoft wireless keyboard 1.0a
The Microsoft Wireless Optical Desktop 1000 hardware set includes the Microsoft Wireless MultiMedia Keyboard Version 1.1a, Microsoft Standard Wireless Optical Mouse Version 1.0a and the Microsoft Wireless Optical Desktop Receiver version 2.1a.
The receiver connects to your computer through a USB port.
The product installation CD that ships with the hardware set includes the software drivers that are required to install the Microsoft Wireless Optical Desktop hardware on your Windows computer.
Insert the batteries that are included with the hardware set in the keyboard and mouse.
The battery installation latches are located on the bottom of the hardware devices.
Place the product installation CD in your computer's CD drive.
The hardware installation wizard will open automatically.
Plug the receiver into an open USB port on your computer when prompted.
Follow the wizard to synchronize the mouse and keyboard with the receiver.
Close the wizard when it finishes to complete the installation process.
http://www.microsoft.com/hardware/mouseandkeyboard/ProductDetails.aspx?pid=058
Jun 29, 2013 | Computers & Internet
Need software driver
JD4539:
Try http://www.driverplex.com It is a Microsoft Windows site.
Jan 17, 2013 | KEIO PS2 Optical Scroll Mouse
My gear head mouse won't work with my MBP
try to go to the website of your mouse and click the support page and click download, to download the software of your mouse.
thanks!
Dec 24, 2011 | HP Internet 3-Button Optical Scroll Mouse...
Logitech with invisible optic After replacing battery, mouse became very erratic, sometimes moving, sometimes not. When "reset" is pushed it works for awhile then becomes erratic again.
Could be a bad batteries. I only use Duracell in mine, however, mine is a Microsoft. Also, check the manufacturers website for driver updates.
Nov 11, 2010 | Logitech Cordless Mouse
Mouse behaving erratically
1. uninstall the mouse and then reinstall the mouse by restarting the PC. Upon restart the mouse should be detected as new hardware and reinstall properly and this should correct the practice behavior of the mouse.
If not then you have a mouse with faulty electronics and needs replacement.
Apr 19, 2010 | Logitech Cordless Mouse
Erratic behavior of MS wireless optical mouse
Your wireless mouse the battery might be low, change the battery and go to control panel and click the mouse icon, and adjust the right mouse speed setting.
hh
Jul 27, 2009 | Computers & Internet
Hyper senitive & erratic mouse
reinstall the driver for the mouse and see if that fixes it.... also you can try going to control panel----mouse and the changing the settings... you may have to experiment abit to get it the way you want it.
Robert
Please take a moment to rate this solution... thanks
May 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
POINTER FREEZES THEM MOVES THEN FREEZES DRIVING ME NUTS. THANKS
When this behavior is observed when using a Logitech product withinWindows® XP, it may be caused by a feature within Windows called"enhanced pointer precision". This feature may conflict with Logitech's software, causing the erratic movement. Enhanced pointerprecision became available in Service Pack 2 and therefore is notapplicable in any version of Windows® XP without Service Pack 2installed. For more information on enhanced pointer precision,please click HERE. If this link does not work, then you should go to Microsoft and search for Knowledge Base article 895550.
Please see these articles from the Logitech database for possible troubleshooting tips as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
Troubleshooting: Erratic Cursor Movement in Optical Mice and Trackballs
Mouse cursor is uncontrollable or behaves erratically
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Interference with Cordless Products
Download latest version of software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 27, 2008 | Logitech Cordless Mouse
Has anyone found a fix (short of getting rid of) for Logitech MX 600 Laser Mouse pointer erratic operation?? Seems to work OK on a Flat smooth surface, but jumps all over the place on any mouse pad I have...
  1. Mouse is not clean.
  2. Optical portion of mouse is blocked.
  3. Moisture or other material on finger.
Mouse is not clean Users who have an optical mechanical mouse (most common mouse for desktop computers) are likely experiencing erratic behavior because the mouse is not clean or is dirty. Optical portion of mouse is blocked
Users who have an optical mouse are likely experiencing erratic behavior because a portion of the optical eye is blocked. Most commonly this is caused by a hair.
Moisture or other material on finger Users who are using a touchpad may experience erratic behavior because of moisture or other material on the finger such as lotion.
Mouse has been cleaned and still has problems If you've cleaned the mouse and continue to encounter issues and this mouse has worked in the past fine unfortunately your mouse is likely defective. One additional test that can be done to help determine if this is the case or not is to connect the mouse to another computer. Otherwise we suggest replacing the mouse.
Oct 24, 2008 | Computers & Internet
My laptop does not recognize my mouse.
Make sure its driver on the mouse is working fine and that windows finds it right click on MY Computer then go to hardware, device manager and right click on Mouse and see if it is installed correctly try reinstalling driver for that mouse.
Sep 10, 2006 | KEIO PS2 Optical Scroll Mouse
KEIO PS2 Optical Scroll Mouse Logo
2,449 people viewed this question
Top KEIO Computers & Internet Experts
Alun Cox
k24674
Are you a KEIO Computer and Internet Expert? Answer questions, earn points and help others
