Question about Memorex MMP8567 MP3 Player
It says boot error shutting down and my pc won't recognise it
When i turn it on, it comes up with the blue screen then turns off showing the message boot error shuting down. when i connect it to my pc, it won't recognise it or see it at all so i cannot even reformat it or update the firmware. any ideas what to do to make it work?
cheers
  • tgaryot Sep 29, 2008
    boot error shutting down.... how do I fix???
  • jtgodu Mar 29, 2009
    My player says boot error shutting down what can I do
Previous solution works if your comp. will recognise the device. Disconnect all network drives and you will be able to access to the device - for format or upgrading, at least it worked for me. :)
Posted on Nov 07, 2011
I have also had the same problem. Go to Google mail and type "MMP8567 boot error" in the search. You will get results where there is links to get the firmware. Especially, from FixYa. Down load the firmware and install it in your PC. Then it will format your player and install the new firmware. Your recorded songs will be lost.
Posted on Sep 25, 2008
Won't boot up Blue screen message is error file ati2dvag
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jul 14, 2012 | Microsoft Windows XP Home Edition
Igxprd32 error
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 13, 2012 | Computers & Internet
Hp invent repeating startup error
If it is showing a blue scree of death (BSOD) and shuts downbefore you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 keyrepeatedly until you see SAFE MODE. Scroll down below Safe Mode and youwill see an option to Disable Automatic Restart. Select it and rebootyour machine. Next time it boots up you will be able to read the errormessage. You'll probably need a system disc or repair disc to fix theblue screen error message.
Mar 26, 2012 | HP xw4600 Workstation - 1 x Intel Core 2...
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
Blue screen
hi is this blue screen is always be previewed when u turn on ur laptop or it appears when ur laptop boot
if this happens when ur laptop boot to ur windows then ur screen will show a blue screen with errors code that show there is a problem with ur pc and this happens to prevent a harmful to ur laptop
so if this a problem write me the overall error message or take a picture of ur laptop when it shows this error message with blue screen and send it to me here or via mail to ghassanalasmar@hotmail.com which is appeared in ur screen with blue screen to tell u how to fix it
Aug 09, 2009 | Toshiba Qosmio G15-AV501 Notebook
Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
Blue screen of death.
Try re-seating the RAM (memory sticks) with the system turned off. Clean out any dust from inside the PC, especially on the CPU fan.
Mar 12, 2009 | Computers & Internet
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Memorex MMP8567 MP3 Player Logo
265 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
