Question about Panasonic AG-DV2000 Mini DV VCR
AG-DV2000 output is black & white only -- no color?
My AG-DV2000 has worked for years and then today it played my pre-recorded tapes in black and white only. I have not touched the cables. Can anyone tell me what is wrong??
I fixed it! It was a menu option that could only be changed using the remote. (I never use the remote)
Q: Why did it change from color to black & white to begin with?
A: Maybe when I unplugged the unit to move it after 8 years of being in the same place.
Posted on Sep 06, 2008
Recording instructions
well if the vcr is hooked up and you can watch a show on it put in a tape that has a movie on it then press play if you can see the show take out that tape put in your blank tape find the show on your tv u wish to record press record try this before the show comes on record a little bit of a show like 30 sec or so then rewind and play back to see if it did record if it did just repete this when the show that you want to record comes on hope this is helpfull....
May 30, 2010 | Panasonic AG-DV2000 Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
the problem of your player is the mechanism to dv tape slut(not mini dv)...it need to calibrate or to tune up...only can fix this is a qualified technician....
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
No color in the viewfinder
ag-456 vf is black and white only.
Apr 24, 2009 | Panasonic AG-456 Camcorder
Problem with playing large dv tapes
I am very familiar with these decks and I repair them. Contact my business Waveform Audio Video, Martinez, California. Email: waveform@wwdb.org
Paul
Oct 15, 2008 | Panasonic AG-DV2000 Mini DV VCR
Cant record in Panasonic AG-DV1000 using firewire
clean the heads; often, heads that will play back a pre-recorded tape may not record because of dirt.
Feb 21, 2008 | Panasonic AG-DV1000 Mini DV VCR
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
