Question about Belkin (F5D7230-4) Router (587009)
Bellkin g router
My router will not conect to my laptop via wierles or by wier
  • jlav Sep 06, 2008
    Have been working fine for a long while, and now I have the same problem -- although router lights are working, and I reset it twice, cannot connect EITHER wirelessly OR via direct connection through the router, though the modem is working fine. What happened?
  • Carl Navarro
    Carl Navarro May 11, 2010
    I'm not there to see what happened. Get your network card settings while the computer works directly plugged into the modem. If you are getting 192.168.x.x addresses, maybe the router is something smart like a Zyxel 645 which acts as its own DHCP server. In that case, you configure the router to NOT GIVE out IP addresses. I'm guessing that this is a DSL modem.
  • 905 Answers
I had the same problem , just unplug the router and turn off the modem for a little while, like a half hour , also restart your computer. things should return to normal. if not there may be something wrong with the modem. also try direct connect to the modem , if you get connected with the modem then it definately your wireless router acting up
Posted on Oct 07, 2008
Can't get conection from router to lap top . just had lt cleaned out. it was hooked up before.
1. Each wireless device has to be allow to connect to the router via a specific IP address assigned by the router in its router table.
It also can setup a wireless device, such as a laptop or phone via a MAC Address ( Media Access Control) number that is assigned to almost every wireless device.
2. Check your user manual for correct firewall and wireless setup.
3. Your manual should be on the CD that came with your router (PDF format)
Feb 19, 2011 | NetGear WGR614 Wireless Router
Trying to conect laptop to virgin media with netgear wireless adaptor the signal is strong but could not conect windows say to contact provider provider gave me number to enter 192.168.0.1 now i am lost
The router is not connected to the internet via Virgin media.
Your computer is connected only to the router wirelessly, that is why it says contact your internet supplier on how to connect the router successfully!
Jan 12, 2011 | NetGear WGR614 Wireless Router
Just purchased acer aspire...... does not accept wireless router . all details entered right.
I take it you have configured & instaled on your laptop?
Can you accees same via anyother device (PDA, mobile, PS3 etc) if so, then its your laptop & not the router.
Can you conect directly to the router (ethernet) and get access to the net or the router itself? If so, it your WifI is duff?
Dec 31, 2010 | Computers & Internet
I have lost my password for our Bellkin 54g Router
Performing a hardware reset on the router Setup steps:
  1. Locate the reset hole on the router. The button will be on the back or side of the router.
    See images below:
  1. Leave the router powered on.
  2. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  3. Remove the paperclip.
  4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default.
Hope that helps!
Mar 18, 2010 | Belkin Computers & Internet
I just reset a belkin g mimo router I cant conect
connect your laptop to your router via patch cord to be able to access the router configuration, then configure it, change the wep keys..etc
hope this thing help
Jan 10, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
My router wont configure
Plug in the laptop to the router and the router to the modem. Power cycle the modem. Turn on power to the router. Copen a command prompt on the laptop and type 'ipconfig /all' and press Enter. Look for your IP address (should have been assigned by the router and should look like 192.168.1.x). Also look for the default gateway. It will probably be 192.168.1.1. If that is the case, you should be able to use your web browser to connect to the router to check its configuration and the WAN status by typing in the address 'http://192.168.1.1' (or whatever was displayed for the default gateway previously.
Apr 11, 2009 | Dell Inspiron 4150 Notebook
Bellkin G+ Mimo usb adapter - invisible
Use this tip as a check list.
Check if you set the correct SSID + Key and "connect if router is not broadcasting" set in your adapter configuration.
If you do not know Key you need to reset from Router.
If you missed SSID you can check on any PC when connected to WLAN and retrieve the name of NON BROADCASTED network
Jan 20, 2009 | Belkin Wireless-G Plus MIMO Router with...
Network
Acer Crystal Eye webcam
Nov 21, 2008 | Acer Aspire 4315 Notebook
Although the internet connects on my PC my laptop won't connect via the router
check that your router is working that lan cable is working, and right click on network places in your laptop screen go to the properties and check there local area conection is enable if disable enable it and check your ip, if there is no local area conection you have to install the network adapter driver
Sep 27, 2008 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
55 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
