Question about Digi-Tech DOD-Digitech 231 - 31 Band Per Side Equalizer Home Equalizer
Amp keeps shutting down.
My radio cd player has a pre amp built in it and I am wondering if this is why my 2CH 1200 watt amp. keeps shutting down? also I am running a 4 CH amp. to increace power to six speakers inside the car and the 2 CH is for the kicker box in the trunk only.
Is there a fuse or someting for the CD plyer or radio? My CD player wont work.
there is a fuse in fuse box that powers radio...sounds like a problem with radio itself....if fuse was bad it simply would do nothing"no power at all.
Aug 16, 2012 | 2005 Buick LaCrosse
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
Jul 10, 2011 | Audio Players & Recorders
My sony xplod 1200 whatt amps red light keeps coming on all the wires are good when it gos to hit it gos red
check your ohm load on the sub and see if your amp can do the same, That is why every time it shuts off into protection mode. Check your gain level on the amp to this is not a volume knob for your amp, It is to get both the amp and cd player on the same page. Hope this was helpfull
May 19, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Sound card recommendations for high end hi-fi
Find somewhere that deals Yamaha pci cards and a good rep will do the rest, for what you are doing I ONLY recommend Yamaha. Clearest sound going hands down. NICE setup by the way! My closest freind does sound mixing for live events in the Moncton Coliseum and swears by Yamaha, through much trial and error, for the xcard.
Aug 16, 2009 | Audio Players & Recorders
Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
Mar 07, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Alpine subs not hitting hard
could it be as simple as bass boost??? maybe you have the subs hooked up wrong... have to have the ohms right.....hopefully this helped
Jan 26, 2009 | Pioneer GM-X962 Car Audio Amplifier
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
No sound comes out of the left pre outs
It sounds like the preamp wire that carries the left channel signal between the HU and the 2ch amp has an issue. Here's two quick things to check.
  1. Check that both ends of the left preamp cable between the deck and 2ch amp is not loose or disconnected.
  2. Swap the left and right preamp connections at the amp. If the issue stays with the left channel, the issue is with the amp. If the issue moves to the right channel, the issue is with the preamp cable or the HU's preamp output.
Let me know what you find out!
Mar 13, 2008 | JVC KW-AVX800 CD Player
Open Questions:
Top Digi-Tech Audio Players & Recorders Experts
Are you a Digi-Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
