Question about Acer Aspire 4315 Notebook
Need instruction on how to install memory upgrade
Hello.
I have a Toshiba Satellite M105-S3041 laptop.
This model comes with only 512 Mb of memory. I am going to expand to 4Gb and looking for detailed instructions on how to install memory upgrade for my laptop model. I also would like to get some info on where to find the tools/items necessary when working with laptops.
Thank you,
Yana M.
I have the same laptop, and just went to 4Gb. This website gave detailed instructions and pictures on how to do it. Hope this helps you too. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-2.htm
Posted on Sep 23, 2008
    Scholar:
  • 141 Answers
First you have to determine whether this model can support 4Gb or memory.
All laptops use the same memory. SODIMM (Small Outline Dual Inline Memory Module) chips are readily available. It's actually quite easy to upgrade. First remove the small piece of the casing that covers the top part of the keyboard. This should just snap off. Then you should find some screws holding the top of the keyboard to the case. Once you remove these, the keyboard will easily pop out. Carefully disconnect the ribbon cable connector leading to the keyboard. Then you should have access to the RAM chips.
Therefore, the only tool you really need is a small phillips screwdriver. Be careful when handling the chips.
Posted on Sep 06, 2008
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Where do I add memory to my Toshiba Satellite M105-S3041
There is a panel on the bottom of your laptop, with a Philips screw head andv the number "4" in a circle. Remove this screw, and the panel. Under this panel is the memory module(s), and they will take up to 1GB per module.
Oct 03, 2009 | Toshiba Satellite M105-S3041Notebook
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
Toshiba Satellite M105-S3041 clock problem
Chances are your CMOS battery is dead, it can be replaced inexpensively if you do it yourself. After taking the laptop apart, locate the battery, it looks like a large watch battery. When you remove it, note the battery type and run to your nearest battery store for a replacement.
Jul 07, 2009 | Toshiba Satellite M105-S3004 Notebook
I FOUND 1 MEMORY SLOT
Hi there.
The memory slots are more or less on top of each other.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Acer Aspire 4315 Notebook
I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
In short.... yeah, 512k is the max.
Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
Jan 24, 2009 | Toshiba 2405-S221 Notebook
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
Ram upgradation
The system uses shared video memory, so it will always show less memory than actually installed.
It's a good machine, but needs all memory it can get for Vista.
Good luck
Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
Acer Aspire 4315 Notebook Logo
200 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
