Question about Radio Communications
Bluetooth it won't pair up with my phone
  • 2 more comments
  • Anonymous Oct 04, 2008
    WHAT IS THE PASSCODE FOR THE BLUETOOTH, IT WONT PAIR WITH MY PHONE WITHOUT IT
  • maxibiker Jan 31, 2009
    My new Nokia E51 will not pair with my visorblade supertooth II
  • darkhole Mar 08, 2009
    My phone is N70 and the HS-4w don't pair with my phone what can i do
    If you don't mind pleas send the solution for my on:
    dark.hole1@yahoo.com
  • Soopafly Mar 19, 2009
    I can pair the E51 and Bluethooth11 but can't get it to connect automatically when Bluethooth11 is switched on.
Pass code for Bluethooth11 is 0000
Posted on Mar 19, 2009
My phone will not pair>
Posted on May 19, 2009
I used 0000 for the passcode in the pairing window.
Posted on Nov 15, 2008
I cant pair my bluetooth to my phone (Blueant X3)
Posted on Oct 08, 2009
4 Suggested Answers
SOURCE: Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Posted on Jul 17, 2008
award462
  • 395 Answers
SOURCE: pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Posted on May 06, 2010
Bluetooth not working
Good afternoon Art.
A soft copy of the owners' manual for the 2011 Malibu can be found here:
https://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals_and_Videos/02_pdf/2011_chevrolet_malibu_owners.pdf
if you scroll through to manual page 7-25 (PDF Page 180), you'll find the info on pairing bluetooth stretching on for quite a ways. It looks like it can practically elope with your phone along with passing along phone calls.
I'm hoping that can help you run through pairing or diagnoses.
(The other thing to potentially look for might be a blown fuse. Forums like this one
Bluetooth phone icon stuck on and radio won work place bluetooth with the Audio System fuse, and say pulling the fuse and then replacing it will reset the Bluetooth as well. The manual noted above, starting on manual page 10-35, goes over the location of all the fuse panels, and pairs fuses to function.
Hope this helps you get to the bottom of it.
Good Luck!
D
Nov 24, 2015 | 2011 Chevrolet Chevrolet Malibu LTZ
Lost pairing of iPhone 5 to Panasonic kW tg7841. iPhone will not pair.
I recommend turning the Panasonic back to pairing mode. It probably came with instructions on how to do it.
Jan 28, 2015 | Apple iPhone 5
I told my Iphone to forget a bluetooth device, how do I get it back because it won't pick it up on my phone anymore?
First thing you need to do is to go into your Bluetooth settings and make sure that your phone is set up to pair with a device. Next, make sure that the device your are pairing to your iPhone, is in pairing mode. After both of these steps are complete, the phone should recognize the device and you can complete the pairing process. Hope this helps!
Jan 12, 2013 | Apple iPhone Smartphone
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
Motorola bluetooth hbm 210 won't pair with kyocera cricket phone
There should be a profile on your Kyocera phone for "Handsfree" note this is different from "Headset" Set it to Handsfree, and then try to pair the two devices.
Jul 20, 2011 | Computers & Internet
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
My wife and I have the same sanyo vero phones. I paired mine to my car sucessfuly. I can't get hers to pair to the same car. Help !
Your car's bluetooth can only be paired to one device at a time. You would have to release it from your ohone to allow it to pair with hers. It's actually uncommon for any bluetooth audio device to be capable of pairing to multiple devices. I know that Jabra is the only manufacturer that I have found with headsets that will pair multiple devices.
Short answer is that it simply won't work.
May 06, 2011 | Sanyo Cell Phones
I can not pair a particular bluetooth device to my n95 8 Gb phone, but i was able to pair nokia's model. is there any reason why other type bluetooth devices won work with n95 nokia 8 GB cell phone? How...
jus change th settings of ur bluetooth on ur device an on th other device an try to pair it.. so tat u may recover tis prob... kindly rate me.... thank you...
Jun 30, 2009 | Nokia N95 Cellular Phone
HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
Jan 30, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Lost pairing?
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Radio Communications Logo
1,683 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
