Question about ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card
I get sound but no vision when connecting my camcorder to the composite input, can you please assist, thanks
    Scholar:
  • 40 Answers
I guess you are using the DOMINO interface included with the card, Be sure to connect it well to the card, a loose connection may leave you soundless too.
Remember to check that your cam is delivering audio through the composite cable you're using and connect it to a TV first to confirm that's not the problem.
Once there, confirm you can watch TV on your All-In-Wonder, if you have that same problem (audio:YES, image:NO) you may have a driver problem, which can be fixed following the next directions.
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (observing WDM drivers).
You should have downloaded the most recent catalyst drivers from ati, and the most recent multimedia center completely (about 80+Mb) that are available for your card.
Also visit the previous versions of the catalyst drivers, the all-in-wonder 2006 seems to be only compatible with the WDM drivers up to ver.8.4 and download it "alone" (don't worry if the latest drivers include the WDM, you can write v.8.4 over it any time).
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them. DONE!
ONCE YOU'VE DONE ALL THE INSTALLING OF THE LATEST CATALYST DRIVERS AND MULTIMEDIA CENTER (is a 4 part download, be sure to install the 4 parts "only the dvd codec is optional" and leave the MMC part to install at last) BE SURE TO INSTALL V.8.4 OF THE WDM DRIVERS (for the all-in-wonder 2006), OTHERWISE YOU'LL HAVE THE SAME BLACK SCREEN WHICH IS ALSO CALLED AN OVERLAY FAIL.
Restart and run your TV, it will work. Please check if your TV comes out at 240i resolution instead of 480i, you might need to disable the TV ON DEMAND feature of the tv program. This is done at the registry. Close the TV program and Run Regedit, then look at HKEY_CURRENT_USER\Software\ATI Technologies\Multimedia\Features\DTV\Channel Manager, the Key you need to change from 0 to 1 is the one called LiveMode. Close Regedit and restart. Start the TV program, and check, you should see the 480i resolution (at the top info bar), if not press ALT+3 and then ALT+2 and then ALT+1 (don't check any of the boxes in any of the questions), that should finally do it. Any problem? Just close TV program and do it all over again from the begining more carefully or trying some little variations in the ALT part.
All this solves many problems as with the TV program showing CORRUPT and BLACK or BLANK SCREENS with AUDIO which are also called OVERLAY FAILURES in many or maybe even all of the ALL IN WONDER (PCI Express or AGP) cards and even with the TV WONDER cards and USB adapters, the only difference between the cards might be the top WDM driver version you migh be able to use with an especific card. Please watch that you might need to try all the versions of the WDM available untill you find the one that works for you (the AIW2006 uses v.8.4, but for example the TV WONDER USB2.0 is able to use the latest available.)
Posted on Jan 04, 2009
How do you use the video out? I can get the sound without any problem but I can't seem to get the video out to another device.
Always check the input on your tv. Depending on where you have placed your composites would determine what input your tv is set at. If I could be of further assistance, please provide tv model and what device you are using to connect to
Sep 28, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
How do i connect to tv for replay
Connect the Camcorder to the TV using A/V cable. Yellow, Red and White combination on the TV side. Probably a single connector in the Camcorder side.
Once you make the connection, switch on the Camcorder in playback mode and play the recordings.
Select input using the input button on the TV.
Please let me know if you require any further assistance.
Mar 06, 2012 | Sony Handycam CCD-TRV37 Camcorder
Is there a way to hook the Camcorder straight to the TV. The vhs adapter I have doen't work.
Here's a link to the manual for your camcorder. Take a look at page 11. There are composite (dont confuse with component) audio and video outputs. If your TV has the same type of inputs, then a direct connection between the TV and camcorder is possible. Otherwise, you will need a composite video converter to change the format to a specific channel, usually 3 or 4.
On the VHS adapter, try changing the battery (also in the manual as well) to restore operation.
Sep 27, 2010 | RCA CC6151 Camcorder
I have a panasonic NV-S90 palmcorder and want to connect to PC
Your camcorder gives an audio and a video signal It is not a tv signal.You need an AV Card on your PC.
Apr 09, 2010 | Panasonic AG-185 Camcorder
How can an old vcr analog connect to a new digital tv
Although the TV is digital, the market has not dumped the analog compatibility (yet). You can connect your VCR through the RF input, using channel 2, 3 or 4 (depending on your VCR) to view your video collection. Or, you can connect your VCR by RCA cables to the composite video input. Most TVs now have only 1 or 2 composite inputs (Yellow, White, Red). They are sometimes shared, serving as a component input as well (Green, Blue, Red, White, Red). For these TVs, you will notice a yellow circle or some other marking around the Green connection indicating that it is also a composite input. When connecting to such an input, remember to connect the white (and red if your VCR has one) to the white (again, red applies) to the audio input jacks of this video input. I hope this was of some assistance and not too confusing.
Mar 23, 2010 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
I dont have picture for recording
Welcome to Fixyah,
If yo can't see any picture please check your video cable connection.
>checked if the video cable is properly connected from dazzle to your camcorder.
>if you connect you camcorder,vhs,VCR using S-video then go ahead and click on option on step number 1 click on video input and then click on S-Video click also VHS input and then click okay.
>If RCA the same thing click on option then video input and then select Composite.
>Turn your camcorder,VHS,VCR on and then hit played button.
>checked your preview screen if the video image is now showing, If showing then start recording.
Regards.
Mar 11, 2010 | Pinnacle Dazzle DVD Recorder
Trying to connect dvd player to sanyo LCD32K30TD. get picture but no sound.
Have you connected the red and white rca/composite cables to the appropriate output from dvd player to the input on the tv that is the same as the video. From there make sure the settings are correct on the dvd player as well as the tv. If you need further assistance let me know.
Thank you,
Lee
Nov 05, 2009 | Sanyo Televison & Video
Use of AV2 input sound socketsto play ipod
The sound is muted unless a video signal is detected on this TV. The only work around would be to connect the camcorder or some other active video to tha input but using the IPOD for the audio.
Jul 23, 2009 | LG RZ-17LZ21 17 in. LCD Television
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
Trouble connecting plz help
This manual has a good section on connecting the camera toa TV.
It should be a matter of connecting the supplied cable to the correct port on the TV. Basically a red wire to a red input a white wire to the white input and the yellow wire (video) to the video in (yellow input)
Please note that you must connect it to a composite video input (not component input) and select playback mode with the TV on the correct input setting.
For a more specific walk through post your TV's modem number and I will be more than happy to give you a step by step.
As far as the drivers for your computer, let me know what operating system you have and I will posta link to them
Mar 17, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card Logo
171 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
