Question about Rio Nitrus MP3 Player
Singing cuts off
When I try to play the file in it, the music is okay, but when it is time for singer to sing, the sound cuts off all in sudden.
  • Anonymous Mar 22, 2014
    did tina arena sing this
    Novelist:
    Champion:
  • 277 Answers
Is this occurs on every file? Rip or Re-encode the songs you wish to use and then transfer them back to the Rio. The purpose of re-encoding is to ensure that there are no bad frames in the completed song file. also try to Rip or Encode your audio at a higher bit rate. if it is try to update to the latest firmware for the Rio. This can be found at http://www.rioaudio.com/support. If you are currently using the latest firmware, flash the Rio again. I hope it will help you.
Posted on Dec 07, 2005
I want to convert an xkr file to mp3
you can download a player to play this files on theur website
http://www.sing-magic.com/
Jan 28, 2013 | Audio Players & Recorders
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
How can i have achieve my dreams to be a singer?
You can do so, by finds learning to sing well. Just by having a good voice, or knowing to sing good, is not enough, you need to practice well and be thorough with the basics. Only after leaning and knowing the concepts well, you will have a better edge in this field. Then you can focus on singing well, by concentrating on the minute details as well. This can help a lot in becoming a better singer as well.
Aug 27, 2010 | Conair Health & Beauty
I use a laptop,an external hardrive,and a mixer amp what is the best way to record some one singing on my karaoke to be able to burn it to disc for them to keep?Do you have any karaoke experts.....
I would suggest you to use a headset (without mic) and play the karaoke for them so that they can listen the music through the headphone while they sing. Connect the mic on the mic plug on your computer and record the songs they are singing with rhythm of the karaoke using an audio editor like Audacity or Adobe Audition and similar softwares. Suppose if you play the karaoke on your speaker, then the music will be heard from the mic and it'll be mixed up with the songs he/she is singing. For best result, Record the sound/songs and save it as different file and mixdown the karaoke file with it later. Otherwise, you'll not be able to get good songs. Please let me know if you need further help.
Good luck.
Thanks for using FixYa.
Jun 14, 2010 | Audio Players & Recorders
Two separate karaoke machines. Mikes (one cordless)
Maybe you could try to write anything more, so that someone else might understand it too.
Are you running it through a noise gate? Maybe you should set the gate thresshold and decrease mic gain or send its signal through a limiter. Because singing "to the sides" of the microphones results in less volume(sound pressure on the diaphragm) than "singing to their top".
Are you using a feedback killer/destroyer/whatever? Try to have the singers stand either behind the speakers or on the other side of the room. I recommend  the first option-much better and easier.
Are you running the signal through a mixing board?
Is there a gain switch on the receiver of the microphones? if yes try to keeep it set i between halfway and three quarters of max, closer to the latter.
If there is too much of signal coming from the microphone, the amplifiers overheat-preventing fuses might cut off the signal, if the mic gain is all the way up and the amp is close to similar heights...
And unless you are a trained singer using a professional condenser microphone or on a small loud live stage with a few monitors, there's no use to sing right in the "top" of the microphone. :) It's nicer from the side, or at least a bit offset.
ask if I missed something and try to be more in depth and specific, as I'm trying to be with my answers. and rate pls
regards
Apr 16, 2009 | Nissindo LX-8080 Microphone
Sound delay in our webcams when we try to sing together.
The speed of light and the speed of sound just don't mix well on a webcams. There is a process delay with these cameras. The only remedy I know of is to get a webcam with greater memory capacity. Say, a 3.1meg webcam. The logitech only has 300K of memory and has a slower response time. Recording with a low res window helps too. 160x120 verses 320x240. This helps with less response delay time between cams. Also, using an external mic helps too. You'll need to tweek the distince between the mic and the webcam to sinc the video and sound. Let me know if I can be of further assistence with this. I'll try to help you resolve this.
Dec 18, 2008 | Logitech QuickCam Communicate STX Personal...
GH3 - no sound from the band/singers!!??!!
I think the problem is that the sound options for the game is turned off or its just set to low. So if you go to options on the main menu you may be able to change the sound options
good luck
Mar 20, 2008 | Sony PlayStation 2 (PS2) Console
Rio Nitrus MP3 Player Logo
50 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
