Question about Cobra 29 LTD CB Radio
Cobra 29 Ltd Classic
Would like to increase the output power of my CB and know that there is a way to do it on the inside of the cb and would like to know how to do it I have a schematic diagram of the radio
    Guru:
  • 773 Answers
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
Posted on Apr 25, 2009
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
To my knowledge, there are four versions of the Cobra 29LTD; LTD, LTD Classic, LTD Classic Gold and LTD Classic China. it is possible that the component/board layout number may differ with the one that you have. Additionally, most of the Cobra 29s uses a variety of Uniden PC78 board. Should you wish to try for experimental purposes only (but pls keep in mind probable difference of boards):
  • Modulation improvement - adjust VR4 to desired level or cut D11or max talkpower remove TR18 ;
  • AM Power - adjust L12, 13 & 14 for maximum power output using a dummy load/watt meter;
  • replace TR14 with 2SC1969 or 2SC1307.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 06, 2008
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Posted on Sep 08, 2008
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
I just purchased a cobra 29 LTD Classic mobile CB radio.Pro tuned high performance Mosfet Final I have a palomar 450 LD mosfet linear.will i have any problems?
Not if the power output from radio to amp is set correct and the jumper for coax is correct length and there is absolute perfect match between them and the antenna used. Afterthought: also the amp better be connected to something big enough to power it.
Apr 29, 2012 | Cobra 29 LTD CB Radio
How to fix the dimmer light ona cobra 29 nw ltd classic
HI I AM TRYING TO FIX MY 29 COBRA LTD IT WENT OUT ON ME
Feb 04, 2011 | Cobra 29 LTD CB Radio
29 ltd classic wont transmit
Great radio when it works.
If you have your settings on CB - not PA - -be sure that your Cobra has that setting selected.
If CB -is selected and still nothing - be sure you have a working mic. These wires are fragile and can break internally. One easy way to check is to borrow a cobra mic or even drop by a CB repair shop and ask them to do a mic check with the mic - it is free.
If you have a bad mic replace it and all should be well.
If your mic is good and it still doesn't transmit you will need to replace the finals in the unit. It is common that these burn out of you got too close to someone with too powerful a radio. The CB shop will need to look at it further and repairs should not be over about 40.00.
Good luck with your Cobra.
Mar 31, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
I need Wire diagram for Cobra 29 LTD Classic CB
http://xbones_antennas.tripod.com/id21.html
May 03, 2009 | Cobra 29 LTD CB Radio
No TX Power
If it is classic it is a 2SC2029 driver transistor.
Nov 18, 2008 | Cobra 29 LTD CB Radio
Cobra 29 Ltd
  • remove TR18;
Sep 07, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
May 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
3,278 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
