Question about Dell 3000cn Laser Printer
Paper jam HAD A PAPER JAM TOOK PAPER OUT, STILL HAVE PROMBLEM!
    New Friend:
  • 159 Answers
Check the paper sensor
Posted on Sep 06, 2008
Fix paper jam
witch printer is it?
Dec 27, 2013 | HP 9040 Laser Printer
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
Epson NX415 Paper jam. I took paper out but it's
Check for other bits of ripped off paper stuck in your machine.
Try turning off your printer for 30 secs and turn it back on.
Mar 11, 2010 | Epson NX415 All-In-One Printer
Polaroid Paper Jam
I had the same promblem and this is how I solved it. If you have an android, screen shot the picture and crop as you desired. Then Press the share button and click bluetooth (Poloroid Zink) and dial in 6-0-0-0 for the password. Only put that in for the password. If it the password entry doesn't come up, that's okay. Hopefully this helped!
Nov 08, 2009 | Polaroid PoGo Digital Photo Printer
I have a paper jam in the back of the machine how do you get the paper out?
open the back door,see where paper jam,could be wrapped around fuser.if no jam,fuser or output sensor faulty.
Jul 07, 2009 | Samsung SCX-4828FN All-In-One Laser...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Paper Jam
you may have broken the paper sensor lever or all of the paper isnt out
Nov 07, 2007 | Dell 922 All-In-One InkJet Printer
Paper jam
hey, give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Paper jam
if it picks up paper then say's jam you most likely have a very small piece of paper still jammed.look for a dent in the paper you pull out,if there is a dent then that's probably the problem.look where dent is on paper and that is where you should look for the piece that's causing the jam,if that does'nt solve problem i would need more info
Sep 22, 2007 | Brother MFC-3240C All-In-One InkJet...
Dell 3000cn Laser Printer Logo
85 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
