Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon PIXMA MP780 creates an "off-hook" condition for phone line 2
I've had my Canon PIXMA MP780 connected at my house both when I've had two active phone lines and one active phone line -- currently I'm using one line. Nevertheless, with my PIXMA connected, my two line phone "thinks" the second line is off-hook all the time, vs. simply disconnected. I'm pretty sure the PIXMA is responsible. Any suggestions?
  • 859 Answers
Does your Pixma multifunction printer have two lines in? for line 1 and line 2? Your active line should be in line 1 of course.
However, I do not think your printer is the source of the problem.
When the phone company turns off line 2 they can do it one of three ways depending on the generation of your local telephone system.
At the back of your home or in the office building there should be a telephone network interface box. Once section if open to the customer to do basic tests, the other is reserved an uses a security screw head to keep you out. You have either red/green and yellow/black or blue/blue-white and orange orange-white wires. Each color refers to tip and ring in telephone polarity. If these are reversed your phone will work but not well.
For your smart phone with two lines in, I'd check out at the box and switch the wires for black/yellow or orange orange-white. When these are reversed the 'polarity' is off but voltage would still be present. In your case, the smart phone MAY be reading the crossed wires and giving you a line open vs. a line empty/disconnected which is nearly the same thing.
If you still have the second set of lines connected to your phone disconnect them from the phone and then underneath the phone you MAY find a switch to hard set your phone for single line or double line.
Let me know how you make out.
Posted on Sep 06, 2008
Power is on to my Canon Pixma MP780, but no display
I got such problem on my MP 780 (grayed boxes on bottom LCD line, no function). It turned out to be missing 1.5V for CPU core. On revese (solder) side of mainboard i found point described as "1.5V". I've powered this from external supply (took about 2 amperes) for few seconds and MP is alive again (without external supply).
Jun 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Can the Canon Pixma MP780 printer be made to print wirelessly
The MP780 is not a wireless printer. It must be connected via a USB cable. Please see the information here:
Canon MP780 Support
Thanks for using Fixya.
Nov 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My canon Pixma MP780 suddenly would not turn on, after 3 years. Checked the cord, changed wall plugs, the lights flashed but then went dead. Help, pleeze
(1) Check the power cord
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
That's what the service manual says for your problem!
Jul 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
When i scan on my Canon Pixma MP780 printer i get a red line down
This is what the service manual says:
(1) Clean the Document glass.
between the contact sensor
and SPCNT board (JCCD1).
(3) Replace the SCANNER
(4) Replace the SPCNT board
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My canon PIXMA MP780 isn't receiving faxes. The in use light is blinking but nothing is coming through. I believe it's hooked up correctly. How do I troubleshoot it?
Check and make sure that the line coming from the wall jack is plugged into the port marked with an "L". The other port is to connect a telephone set or answering machine.
Jan 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
141 people viewed this question
old marine
old marine
