Question about Panasonic KX-T7730 Corded Phone
Call waiting is it possible to activate call waiting feature in this corded phones like how it is in the mobile? say for example i am on line and someone is calling me from the intercom it should notify me by blinking or by a beep showing the number of the caller as well.
  • Panasonic Master
  • 2,460 Answers
Since the phone is basically stupid, it's hard to say. The 7731 has the capability of what you ask...if...the sytsem does.
When you find out what cabinet the 7731 is connected to, post back and you'll get the codes. In the meantime you might try looking in the book for Call Waiting C.O On a TAW-848 the code is *7311. On a TA-824 it's 7311#.
Carl
Posted on Sep 06, 2008
Hie,i'm using gt-s5233a so how can i activate my mobile tracker
someone inserts a new SIM card in your mobile
phone, the mobile tracker feature will automatically
send the contact number to two recipients to help
you locate and recover your phone.
To activate the someone inserts a new SIM card in your
To activate the mobile tracker,
1. In Menu mode, select Settings ? Security ?
Mobile tracker.
2. Enter your password and select Done.
3. Select On to turn on the mobile tracker.
4. Select Empty under Recipients to open the
recipient list.
5. Select Add recipients ? Phonebook to open
your contact list.
6. Select the contacts you want.
7. Select a number (if necessary).
tracker,
Mobile tracker.
recipient list.
your contact list.
Mobilepriceshop com Full Phone Prices and Specifications
Jan 01, 2016 | Cell Phones
How do I get the feature key to stop blinking?
These phones work on about 8 NEC phone systems, but most are just newer versions of the same system. So, most likely the callback feature has been activated. Someone internally calls you, you don't answer, they dial # to activate callback. You come back to your phone, see feature key flashing, lift handset, dial #, call goes to whoever set callback, then feature key stops blinking.
Jul 07, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Avaya Partner 18D Corded Phone...
Yes. Call forwarding is a feature provided by your telephone company, not a feature of any phone, and the procedure is dependent on the company. For some telephone companies, for example, you forward a call by dialing *72, waiting for a second dial tone, then dial the number to which you want calls forwarded. Please contact your telephone company for their exact procedure.
May 28, 2012 | Avaya Corded Phone avaparp18d
I have a AVAYA 6408 phone and it is going strait to voice mail when someone calls and I cannot get that off
You activated that feature yourself by hitting *3 you may want to use this when you go on vation so it goes directly to VM. #3 will deactivate this feature.
Jul 20, 2011 | Avaya Definity 6408D Corded Phone
On my activity report, under comment is states TX ECM I know the TX is transaction (I think?) what does ECM stand for
ECM (Error Correction Mode)
The Error Correction Mode (ECM) is a way for the fax machine to check the integrity of a fax transmission while it is in progress. ECM transmissions are possible only between machines that both have the ECM feature. If they do, you may send and receive fax messages that are continuously checked for their
integrity.
Sufficient memory must be available in your FAX/MFC for this feature to work.ECM (Error Correction Mode) Detects errors during fax transmission and resends the page(s) that had an error.
If you have Call Waiting, RingMaster, Voice Mail, an answering machine, alarm system or any other
custom feature on a single phone line with your fax machine, it may create a problem sending or
receiving fax data.
For Example:
Your Brother machine handles the Caller ID and Call Waiting/Caller ID subscriber services.
However, if you subscribe to only Call Waiting or some other custom service and its signal comes
through the line while your machine is sending or receiving a fax, the signal can temporarily interrupt
or disrupt the fax data. Brother's ECM feature should help overcome this problem. This condition
is related to the telephone system industry and is common to all devices that send and receive
information on a single, shared line with custom features. If avoiding a slight interruption is crucial
to your business, a separate line with no custom features is recommended.
Jan 20, 2011 | Brother IntelliFAX 2800 Laser Fax
The phones have caller id and it works except not in the call waiting. How to I activate the call waiting-caller id?
You'll need to call your phone company. (Qwest, BellSouth, SBC, it depends on where you live)
Call Waiting ID (or CID-on-Call-Waiting) is a separate feature, possibly with an extra monthly charge, but possibly it just needs a free activation
Jun 10, 2010 | Uniden DCT646-2 Cordless Phone
Hello I have a KX t7730 with 4 lines installed in it. the problem is that if person X phones and i am on the line speaking with person Y, than person X go's into voice mail instead of being "dragged " to a...
My office phone is set to Call Forward No Answer to Voice Mail.
I'm guessing that you are learning the difference between the TA series and the TAW or TDA series. Call waiting is programmed from a CW code dialed into the intercom (ie 7311 or *7311) and call forwarding to VM is programmed by a 71x or 710x or *710x command. In a TD TDA or TAW system, you get CF BUSY, CF NO ANSWER, or CF busy/NA.
In a TA you only get CF ALL, or CF Busy/NA.
So, if someone rings your phone while it's busy, there is no indication, just an immediate forward if that feature is set.
Carl
Dec 07, 2009 | Panasonic KX-T7730 Corded Phone
SIM WONT WORK
It is waiting for the Sidekick feature activation, which AT&T doesn't have. You can try having them add a data feature, but I doubt it will work. Sidekick was specifically made for T-Mobile and not meant to be used with any other provider.
Apr 22, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Jun 11, 2008 | NEC Electra Elite 32D-1 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
98 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
