Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
AGITATOR ASSEMBLY DIAGRAM
Please can you help me with a diagram for the above ?
  • Anonymous Sep 10, 2008
    need to remove drum and clean
I need to know how to take the agitator apart. The agitator will not spin, so I need to see what is wrong with it.
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this is helpful to you.
May 26, 2010 | Washing Machines
Top portion of agitator doesn't rotate
repairclinic.com
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
The agitator seems to be loose from the bottom part. will not catch if you spin it manually counterclockwise. before i could turn it manually to stir up the soap
repairclinic.com
May 25, 2010 | Washing Machines
Model # RAS71335WO , NEED TO GET A DIAGRAM FOR THIS MODEL ... NEED TO CHANGE THE BELT. AND IT NEEDS SOME WORK , TRYING TO GET A DIAGRAM SO I CAN WORK ON IT
I could not cross reference the model number you provided to anything. However, if this is a Roper TOP LOADER washing machine, it does not have a belt. This washer is manufactured by Whirlpool and uses a motor coupling instead of a drive belt. This configuration is known as "direct-drive".
If your washer does not agitate or spin, the most common cause is either a lid switch malfunction, or a broken motor coupling. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
repairclinic.com
NOTE: Please verify your MODEL NUMBER again. I suspect the number you provided is "RAS7133SW0", but even that number does not cross reference. However, if you enter "RAS1733" on any of the parts websites, there are many variations of this model washer that are all built the same and use the same parts.
May 17, 2010 | Washing Machines
Will not agitate during wash cycle. If i apply pressure to the agitator then it will but if no pressure then no agitation
repairclinic.com
May 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator is not agitating. Cant seem to get
If this is a Whirlpool manufactured TOP LOADER, and this is a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
If you have any questions, please post back and let me know. I hope this helps you.
Apr 26, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
The agitator arm is intermittent on my ultimate care II
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
Apr 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore stackable , agetator cone does not move
If this is a Whirlpool manufactured top loader (such as Kenmore), the problem may be a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Replacement parts can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. The agitator parts are commonly sold as part of their in-store inventory.
Mar 10, 2010 | Washing Machines
The agitater will not turn unless I push down on it
If this is a Kenmore top loader, the problem may be a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Whirlpool manufactured washers (such as yours) uses a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
repairclinic.com
If you have any questions, please post back with a MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) if it is different from the one you posted this question under. I hope this helps you.
Feb 21, 2010 | Kenmore Washing Machines
The agitator sounds like it is grinding and shacky. It is not agitating properly
If this is a Whirlpool manufactured top loader (e.g., Kenmore, Estate, Roper and some later model Maytags), the problem is either a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Whirlpool uses a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
repairclinic.com
Feb 18, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
409 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
