Question about RCA RS2020 CD Shelf System
Fuse We have an RS2020 CD Micro System. It is a CD player, tape deck, and tuner. The fuse blew, so we bought a new one. We put the new fuse in, then plugged the unit back in. As soon as we plugged it in and turned it on, it sounded right, then we got a bright green light, and the fuse blew again. This happened twice. Incidentally we had disconnected both speakers from the unit beforehand. What might be causing the fuse to blow as soon as we plug it in and turn it on?
    Novelist:
    Champion:
  • 277 Answers
If the fuse blew again then there is more than likely a problem with one or more of the boards components. First start by unscrewing the power supply and looking on the underside, you may see some burn marks. If you do then it is likely that the component above the burn marks has blown and needs to be replaced. If you do not see any burn marks then the best place to start is with the diodes on the board. If its still not working, e.g. the fuse blew again then it may be that the problem lies elsewhere on the power supply... Good luck.
Posted on Dec 06, 2005
No sound when I play my CD on my Micro Hi-Fi System
you have cd output sound before or never you get sound from cd if you never get sound from CD then u call Service Center
May 21, 2012 | Audio Players & Recorders
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
I have a Amp,CD player,Tuner,and DVD player. no a tape deck.how can i conect all, with out a tape deck through eqeualizer.
You can connect the EQ on the tape in/output of your amplifier. Tape out (or monitor out) to the input of the EQ and tape in to the output of the EQ.
Listen to the tuner and than switch to the tape input, the tuner input will be still active. But in the tape "mode" your EQ will be active too.
Regards,
Gerard
Jan 10, 2010 | Yamaha EQ-70 Home Equalizer
I have a rca rs2640 stereo system. The display, cd player, tape player, radio, and headphone jack all work. But when a cd, tape, or radio is playing, the speakers do not make any sounds. I know it is...
It sounds like maybe you have speaker wires touching somewhere. If they are touching it will blow fuses, especially if you turn the volume up to try to hear anything. DO NOT put bigger fuses in to replace the old ones, you will actually do more damage to your system because a higher volt fuse will allow a higher voltage to "spike" in your stereo and might just start frying internal parts.
Aug 10, 2009 | RCA RS2640 CD Shelf System
2000 escort - tuner does not work but CD and TAPE are fine
most likely is the radio itself- typical ford radio... best bet is look in a junkyard for a new radio- there are no fusible links- there usually is just one 10amp fuse in the inside fusebox. but if the cd& tape players work it is in the stereo itself. hope this helps and good luck
Jun 08, 2009 | 2000 Ford Escort
Radio doesn't work blew a fuse
radio and clock doesn't work.  Is it the fuse?
Aug 08, 2008 | 2005 Toyota ECHO
RCA RS2020 CD Shelf System Logo
128 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
