Question about Gateway Computers & Internet
The machine doesn't think there is a video card in it. This just started to happen.
  • 33 Answers
If it has an on-board card, then check if it is enabled in the BIOS. if it is, then chances are, it is broken, and you might need to buy an AGP or PCIx one. if it is a dedicated card, however, try to reseat(i.e. remove, and place it back) the card in its slot. make sure it is turned off. then turn it on and check if it detects now. if it still does not, then the card might already be broken.
Posted on Sep 06, 2008
Despite memory card and game inserted game doesn't start
some games store profiles and game play. you might have a profile only.go into memory card and click on data and see if it says profile.if it does there is no game data
Sep 06, 2012 | Sony PlayStation 2 (PS2) Console
Dell computer lose screen while playing games in facebook
Something that happens to me as well. Video card upgrade maybe some more memory of Facebook is just flawed, If the machine works fine everywhere else then I would not sweat it. If it does this while watching a DVD or a video online you may want to consider a newer upgraded video card for your machine. Also a good internet connection as well as speed may have something to do with this issue. I think we have all faced this issue at one time or another. John
Apr 08, 2012 | Dell Inspiron 4150 Notebook
My dell 160l does'nt have video card.how can i install?
A Dell 160I is a printer, as far as I know. They don't come with video cards, although many modern printers have a small LCD display.
Apparently yours doesn't have this.
If you don't have it, then you're stuck with what you have.
Mar 30, 2012 | Computers & Internet
No P.O.S.T., computer doesn't start up
Remove HDD, RAM, any cards (assuming you have a built-in video adapter)and see what happens. You could also remove the processor and try again. If none of this works then try a new power supply.
Jul 08, 2011 | Computers & Internet
Playing a downloaded film with HDMI cable to my TV set Sony Bravia, after 10 minutes the colour on tv set disappear or change. Do I need a certain drive on my computer for HDMI
If it was playing the video fine initially, there should be no reason for that to change. Most likely the video card on the laptop is overheating or dying, which results in the change in colors. I fix laptops at my computer repair shop, and most are HP Pavilion DV6000 and DV9000, and they are notorious for having bad video chips on the motherboards. If it is still under warranty I would back up your data from the hard drive then send it in to HP to have fixed or replaced. If it isn't under warranty I would try to connect your tv using just a VGA cable, and see if the same thing happens. If it does, you have a bad video card. If it doesn't happen then you may still have a bad video card, it's just that the VGA signal isn't as high powered/high resolution so your card doesn't get pushed hard enough to malfunction. Try the VGA cable and let me know how it works.
Jun 21, 2011 | Computers & Internet
Video card or driver doesn't support the required fixed-function texture blend operations. DirectX 7 rendering path will not be available. Video card or driver doesn't support direction lights in...
Hello, the problem seem to be related to the video card you're currently using, See if you have an integrated video card: a hint to find out is to see behind your computer if the monitor connection is on a side of the back panel is probable you have an incompatible integrated video system, you can solve this problem by buying and installing a compatible video card as any Nvidia or ATI card, Call an IT professional and ask for some advice on what card you should buy and install to make these problems disappear, also ask him/her to install it for you.
Have a nice day, and If you have any other questions you can come back and reply.
PD: If you still want to buy and install it yourself ask me again and I'll help you.
Jun 03, 2011 | Microsoft Windows XP Professional
Hp laptop dv6000 won't start how to solve
I think you can try this step and see if it makes your laptop work.
1. Unplug the AC adapter and Remove the Battery
2. Press and Hold the Power Button for 30 secs. without the battery and ac adapter
3. Put it all back in and see if the machine will work.
If happened it doesn't work. Try this.
1. Turn off laptop, unplug laptop, and remove the battery.
2. Unscrew all panels on the back of the laptop.
3. Reseat RAM and Hard Drive.
4. Check if the power port is loosed.
If happens those steps don't work it could be with the Motherboard, CPU, Video Graphics or LCD itself that's having a problem.
Hope it helps somehow.
Apr 25, 2011 | Computers & Internet
I have window service pack 3 and my display is not very good so i think my monitor doesn`t work properly so i have started installation of monitor but below massage is displayed``video card driver not...
First of all you have to remove the video card drivers which you have already installed.Restart your and again install the video card drivers.and restart your PC again.
If the problem persists, then,you have to find appropriate drivers of the video card, and install them
If you need any further assistance please feel free to contact me again.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 27, 2010 | Computers & Internet
Computer turns on, but nothing happens
looks like you have a bad video card try to reseat the video cable to see it that helps if not tri a new video card.
Jan 16, 2009 | E-Machines eMachines Desktop PC
Graphics Card Problem
im sure that is AGP, because we have the same video card on my other computer. your PCI slot is for sound cards, link modem, etc.. whenever your playing games make sure that you put the video option in to medium or low because that starts the heat of your video card when you use it into the limit. Try to cool the video card if its happening the heat again by using a fan and aim it to the video cards.
Others are overclocking their video cards to push the capability of the video card over the limit. their using a cooling fan or a tube like to maintain the temperature of their video cards. hope that helps
CHARCOIS
Jul 26, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
