39 Other Users Have The Same Problem - Continued
Comment by tpgeck, posted on Aug 22, 2008
CoffeeMaker lights up but does not brew. Tried everything, nothing heats up.
Comment by rjcipperly, posted on Aug 11, 2008
Same problem.somewhat intermittent......when I check all the connections at the base, it works fine the first time.then, nothing......how about if I just bypass the thermal breaker....will that tell me if it is defective if the machine works OK?....most cheaper coffee makers don't have the breaker at all and this has a auto off switch after an hour (or more) so i am not to worried....thanks
Comment by Guest, posted on Aug 03, 2008
only a few months old. Pot started 'gurgleing' and takes water stops passing over grounds. I've had other Mr. Coffed pot for years but never had a problem. Time to try something else
Comment by Guest, posted on Aug 01, 2008
After water and coffee is is put into the filter, the button is pushed and it takes 1 hour 10 minutes for the water to go through and the 3 cups of coffee to brew. We have had it with Sunbeam products and are purchasing another brand tonight.
Comment by gregman70, posted on Jul 23, 2008
Coffee will not brew, put in water and coffee turn on then nothing happens. heating plate does not get hot either.
Comment by cgtalbott, posted on Jul 21, 2008
ADX20 light on but no heat. 2 thermal fuses in series both check fine with ohmmeter. A small 3/8" diameter thermostat?? appears to be defective.
I am currently trying to find a replacement part but not sure exactly what this part is.
Comment by Guest, posted on Jul 19, 2008
no coffee coming out
Comment by kq277, posted on Jun 24, 2008
My coffee maker stopped working (i.e. nothing happens when you press the "on" button) after less than a year. I have tried to get in touch with the manufacturer, because there is supposed to be a 2-year warranty, but phonecalls are not answered and the e-mail address they provide on the answering machine is not accurate. How can we contact the manufacturer? And would this situation be covered under warranty?
Comment by apachie, posted on Jun 15, 2008
put coffee and water in ,will not pump water up into coffee g,then it starts to beep as if coffee was finished
Comment by Guest, posted on May 29, 2008
Haven't used the pot in a few months.Now, I put in the coffee grounds and water, plug in to the live outlet, turn on the pot and nothing happens..Acts just as if there is no power.
What is my problem?
Billy G Smith
Comment by mkas9999, posted on May 27, 2008
When we turn on the Krups FME4, the "Reservoir Empty" signal comes on and of course will not brew coffee. Any suggestions? Thanks!
Comment by coffehead, posted on May 15, 2008
coffe will not brew on any setting. It starts for 30 seconds then shuts off.
Do I need to clean it? It has worked fine for 2 years
Comment by CAP35, posted on Apr 26, 2008
Yes I have the same proble
Comment by rodi915, posted on Apr 05, 2008
Brand new machine. When we poored in the water for the pre-rinse use the water went through fine. However we have tried numerous times with and without coffee, but no water comes out through the broiler outlet. The frother works fine, but no coffee.
Comment by confusedinmo, posted on Apr 05, 2008
When we put in the water and turn it on, nothing happens. The light is on but it never does anything
Comment by Guest, posted on Mar 31, 2008
coffee
maker is making coffee. Does it require special cleaning?
Comment by Coffeetime, posted on Feb 29, 2008
I have a B70 and love it. The machine shows "ready to brew" place a Kcup in, close the lever, then the press the button for a coffee. When the button is pushed, the machine does nothing and then goes back to "ready to brew" I'm looking to see if anyone can help me fix the machine.
Comment by Princess24, posted on Feb 08, 2008
nothing happens when I turn it on it shows that is suppose to brew by saying fresh but that part never turns off. Water does not filter through no coffee is made
Comment by Elizabeth2, posted on Jan 17, 2008
Same problem but I have a brewing sound and then after 15-20 seconds the brewing sound starts to slow down then stop. Nothing brews, not a drop. I cleaned everything out and tried again and the same thing happens. I have only had the machine for 3 months. The espresso side works fine. Please help! Thanks!
Comment by donlanham, posted on Jan 07, 2008
Hi
My coffee maker is grinding the beans and then begins the coffee process - it will stop with only two or three cups made instead of the whole pot. I have to continually resart the process until all the water is gone. Initially, we had water overflows and found that the coffee maker did not complete its full cycle. Is there a reset button or something? Don
Comment by Guest, posted on Dec 31, 2007
worked fine up until last few days. Reset by unplugging and plugging back in. Plenty of H2o in unit. Put K-cup in unit- when I push start it doesn't brew coffee. No water comes out. Unit indicates that it is heating fine. Can you help. I have also tried using another electrical outlet.
Comment by dsrich, posted on Dec 31, 2007
We put water in, coffee beans, turn it on and it only brews one cup or two at most and stops so we have to keept urning off and staritng over again? We then push 1`-4 cups although we watn 10 cups and it gives another couple cups, it is a constant struggle.
Comment by Guest, posted on Dec 21, 2007
NO COFFEE COMING OUT!!
Comment by jburns, posted on Dec 14, 2007
Gevalia coffee pot has worked every day for over a year. Put water and coffee in turn on and nothing happens.
Comment by lamttm, posted on Dec 04, 2007
I turned the unit on the water tank is full. When it says ready, I put the coffee pod in and press either small or large cup, Nothing. It says ready again.
Comment by Rosa Naranjo, posted on Nov 28, 2007
I place disc w/ grounded coffee and add water to my coffee maker and turn it on and the heat lamp works but after that nothing happens the power light stays flickering but after that nothing happens. what should I do I tried to clean it w/ Vinegar but yet it does nothing.When My daughter came over she was going to make coffee for my husband and I and alls it did was make a very lite lokking brew of coffee but coffee was very cold and only made about 2cups but nothing else when she place enough to make a full 12 cups . What should I do?
Comment by 1100, posted on Nov 28, 2007
I can't get the coffee to brew
Comment by Doc Bundy, posted on Nov 27, 2007
Partial brew ONLY!!! Two cups at a time out of ten desired. Have to keep hitting the BREW button. Two different coffee makers happining at same time that used to work just fine before move ??????
Comment by Guest, posted on Nov 24, 2007
I used my mrcoffee maybe 20 times it was okay now it will only brew not even two cups when I want a 6 cup brew.
Please help this is a brand new machine. We hardly ever used it.
thanks
Donna in New Jersey
Comment by Guest, posted on Nov 19, 2007
coffee brewsonly partialy, the light comes on with the coffee only half finished.
Coffee brews only partialy and light comes on
Comment by Guest, posted on Nov 11, 2007
coffe maker has stopped working- all the lights work. I have never used it as a programmable just tutned it on and made coffee.
Comment by Guest, posted on Nov 10, 2007
continuely poops the circuit breaker
Comment by Guest, posted on Nov 04, 2007
I put the disc with coffee inside and close the cover, the watertank is right, the heat lamp is working and after that- all lights are flicking and nothings happend. No brew, no hot water, no coffee,nothing! We are living in Singapore and don't know how to find a Service Center on the island for the Tassimo. Please send me an adress in Singapore!!!
