Question about Refrigerators
Door alarm goes off every 4 minutes (plays music}
The door alarm goes off every 4 minutes and the temp is up to 9 degrees I Have similar problem with samsung refrigerator SRL551DP, door alarm goes off every 60 seconds for no apparent reason all doors closed, we tried reseting it by unplugging it for 15 min as suggested by samsung customer service, but to no avail, and the temperature of the fridge is unresponsive stays at 9 degrees, i called them again and they said that was the only solution they could suggest..
  • Gerry50 Nov 16, 2008
    I have a very similar problem. My fridge is a Samsung SRL551DP. The alarm repeats itself every few minutes and the temperature of the fridge is 9 degrees. The light was originally not working, but now it appears that it will not turn off. As the light is linked to the alarm switch, I thought that perhaps the problem resided there. I have tried unplugging the fridge, but the problem was not resolved. Whatever help you can offer is appreciated!
5 Suggested Answers
  • 5 Answers
SOURCE: temperature in refrigerator is now at 60
sounds like the defrost system is cutting up, it melts the ice in the freezer compartment to allow cold air from freezer to travel to fresh food side and back again, could be a damper control but very rare event.we use to have to melt ice manually in freezers now we have automatic defrosters do it for us. this is not the easiest repair but the defrost sysem is replacable and not the end of your frig.u can empty frig and turn it off for 24 hrs with doors open and let it defrost naturally,so as to make sure that it is a defrostsystem, after 24 hrs turn back on and see if it works correctly after 6 or 8 hrs, if so definite defrost problem.
Posted on Oct 08, 2009
heatman101
  • 43501 Answers
SOURCE: Refrigerator (VCFF136SSS3) internal temperature is
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 05, 2010
guru_fixya
  • 944 Answers
SOURCE: A problem with Samsung refrigerator
It seems the problem is with the control unit board.You can replace it or take it to the service center to service the board.If your fridge is under warranty and if you dont have hands on then call service man and remove the board.The location of the board varies from model to model.I feel door alarm is not important for you.You can ask him to cut the alarm sound.He will short the alarm wire.You can save 50$ on replacement of the board because its a small problem.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 05, 2011
  • 8 Answers
SOURCE: need to turn off the
Whats the serial number of the fridge Its on the top of the sticker in the fridge and on the sticker on the outer left side of the freezer
Posted on Mar 22, 2011
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
2004 Saab 9-3 Cascading electrical problems
Did you sovle your problem? then how?
Oct 20, 2008 | 2004 Saab 9-3
Theft alarm sounds w/o provocation
This sometimes can also be related to the internal batteries in the alarm ECU or alarm siren module going bad. If your handy the internal batteries can be replaced without buying a new replacement unit. Otherwise, the entire module must be replaced ($$$). Lastly, you can have a Saab indy or dealer disarm the theft alarm on the vehicle. You retain your keyless operation, but the alarm is not active. This is done in the programming and adjustment menus in the TWICE unit with the Saab Tech 2 computer.
Justin Duthie
Strictly Saab
Melbourne, FL
Aug 24, 2008 | 1999 Saab 9-5
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
i'm got a Samsung RSH1DTMH side by side and its doing the same thing. it seems to be once a week. Last night i opened it to get a drink about 23:30, and then dealt with the alarm, reset 10-15 minutes until 01:30 and then said "F-it" at that point i didnt care if i lost everything i n it. it stayed at -25 in freezer all night, +7 (set to +3) in fridge all lights on, normal operation noises. WHAT THE F GIVES SAMSUNGGGGGGG
Oct 12, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
