Question about Dell Inspiron 1300 Notebook
Screen goes blank soon after switching on
I have a Dell Inspiron 1300. It worked fine until yesterday.
When I switch on it starts as normal for the first few seconds
ie I can see the F2 Setup and F12 options. Then I get the single blue banner with www.dell.com at the top and then a brief message flashes up
'Loading PBR descriptor.....done....' but then the screen goes blank.
Any suggestions would we welcome - I have gone into Setup and done disgnostic test but all seems ok.
Thanks
Robert
Thanks
  • roberisk Sep 07, 2008
    thank you
    I tried f8 safe boot and it stops after a few seconds with
    ...partition(2)\windows\system32\drivers\classpnp.sys
    does this mean i have to reformat c drive?
    Thanks
    Robert
    President:
  • 778 Answers
Try "Safe Mode" (holding F8 key on boot and selecting "Save Mode"), then run diagnostics and an up to date (virus definitions) Anti-Virus full scan.
If Safe Mode is not accessible then you may want to consider a format and clean install by booting to your Windows (?) CD.
Posted on Sep 06, 2008
  • Frank  Fernandez
    Frank Fernandez Sep 07, 2008
    Robert,
    Yes, sounds like a format (NTFS Normal and not NTFS Quick) and clean install of Windows will either fix this problem or point to another cause (I doubt another cause but can't be certain). I believe the format (NTFS Normal) and clean install should get your PC back to good operating status.
    Good luck
Hi, i am having dell inspiron 1525. when i am switching the power on it starts normally but as soon as dell logo appear (at the bios startup option where we can press F2 or F12 for bios)it gets...
1. You may have a power supply issue. the power adapter is not completely charging the battery.
2. You battery may not be holding a charge and needs replacement.
3. Contact Dell support for a technical support.
Aug 10, 2010 | Dell Inspiron 1525 Notebook
Hi. I have an Inspiron 1300. Suddenly, the screen ...
Black screen is often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have your screen be checked for possible damage.
Hope it helps.
Thank you for using FixYa.
May 21, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron 1300, g and h keys suddenly stopped
There are some circuits malfunktion in your keyboard.
Try to connect and external keyboard and you will see that the external keyboard works fine.
This way you can continue using your computer,
and continue writing,untill you get a replacement keyboard.
You need to replace the keyboard.
Hope this helped you to continue using your computer.
If you were helped. Please vote!
May 12, 2010 | Dell Inspiron 1300 Notebook
Blank screen
If, when it does start and you see normal screens your version of Windows is probably corrupt or you have some type of virus. I would recommend wiping your hard drive and reinstall Windows.
May 06, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
May 01, 2010 | Dell Inspiron 1300 Notebook
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron password fault
Hi my inspiron 6400 cannot boot up after trying several time .I press switch on, then after 3 second it goes off again.Battery fully charge.
1)battery new
2)rep used mother board
3)rep touch pad
4)rep keyboard
I hope anyone that know this fault .Kindly help me with the issue.
Mar 08, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1300 Notebook Logo
287 people viewed this question
Alun Cox
