Question about Samsung Refrigerators
Ambet temprature inside fridge when set on 1C
Hi, I have a brand new side by side, model RSJ1kEMH1, the fridge is not getting cold. I have selected the coolest temp on 1, what should the temp fall to inside when selected 1C. I have selected 0C in the cool select zone and the food is not cold and does not last. I have placed a temprature meter inside and when left closed for 24 hrs the coldest it gets is 5-6C when set on 1, surely this canot be corect. What should the temp be inside when set on 1C?
I'm really very dissapointed in this fridge and paid a lot of money for it, my LG frost free when set on 2C freezes the food in tge fridge and last far longer. Milk get sour before the expiery date for excample??? They have replaced the compresor, sensors and board. Also in the mroning sometimes when I open the fridge it has condensated and everything is wet, doors seal and no leaks, they checked, what can we do or what is wrong???!!!
many thx
  • franco_g Sep 07, 2008
    No the light does not stay on. Inside the fridge there is a thermostat of some sort that measures the temp inside, this was replaced, the compressor and thecomputer board.
    Thus my question if you can help is if the fridge temp is placed on one, what should the min or max corresponding temp them be inside the fridge. My LG frost free if set on 1 freezes ecerything inside , yet this one hardly cools the milk or water for that matter?
    Thx
    Scholar:
  • 141 Answers
I can't help but wonder if the light is staying on... :)
It certainly sounds like a door seal, but did they replace the thermostat, or is that what you mean when you say sensor?
Posted on Sep 06, 2008
Hy i have a problem with my fridge freezer , the fridge compartment is acting like a freezer going up to -16
There is normally an adjustment knob inside the fridge, in the back or top to allow you to adjust the coldness. Numbered 1-9.
If you have already adjusted that it would help if I know the type (side by side, freezer on top or below) and the brand. Most side by sides blow some of the air from the freezer side into the fridge side with internal fans and vents. How is the freezer side coldness knob adjusted?
I would set both knobs to 5 and go get yourself a outdoor thermometer to put in each side. It should be about 35 in the fridge and about zero in the freezer. Remember it will be warmer in the top and colder in the bottom of each.
Was the thermostat you replaced in the freezer or fridge?
Feb 02, 2015 | Refrigerators
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Cant Get fridge and freezer to cool to correct temp
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Jan 02, 2014 | Refrigerators
Hi there, we recently purchased a Bosch Platinum side by side fridge and freezer model number KAN56V40AU. The problem we are experiencing is that the fridge section is not cold enough and the temperature...
you will be able to get a technician out under warranty to properly diagnose the fault
you do not have to return it as they will come out for the job
call the service agent listed on the warranty booklet
don't touch it your self as that will void the warranty
Jul 14, 2017 | Bosch Refrigerators
My mini fridge is a big freezer.
It is the temperature sensor. It is normally attached to the evaporator itself (the freezer part that gets cold).
Jan 06, 2010 | Kenmore Refrigerators
Temprature settings keep changing by itself. Mostly changes on fridge side..freezer temp stays steady for most part. today....all vegetables froze in fridge...lettuce wad hard as rock....please...
Either the temprature control is malfunctioning or the cold air duct dampers stuck up due to forsting. Switch off the refrigerator for 3 hours and restart.
Aug 15, 2009 | GE GSS25IFR Side by Side Refrigerator
My fridge is working constantly it stops only when i select zero at the thermostat switch
Sounds like the cold control is bad.Does the fridge work ok otherwise?The cold control is what you are having to turn to 0,and are usually set at midrange.0 to 9,set at 4.The control has a temperature sensitive tube that opens or closes the contacts in the control,and they do go bad.This is where I would start.You can get a replacement control at an appliance shop.Get the model and seriel number of the fridge located usually inside of fridge on a tag on the inside wall.Use these numbers to get the part.Hope this helps. Gregg
May 29, 2009 | Amana ARS2464B Side by Side Refrigerator
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Refrigerators Logo
174 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
