No audio sound, mic doesn't work. - Computers & Internet
  • 320 Answers
For audio please install the mother board audio drivers for your PC. The driver cd is provide with motherboard when it is purchased. If this doesn't work, try connecting the speaker jack to front panel of your cpu.
For mic to work properly, make sure you connected the pink color jack of the speaker to the pink port of the cpu(Back side of cpu).
If did nor find drivers, download it from the internet by giving the motherboard type and the number.
I hope it should work now. Thank you
Posted on Sep 06, 2008
I installed the lexicon lambda with the disk provided but when i put my mic on the mic input it doesn't record... what should i do? please help!
first thing to do is check your sound and audio settings, goto control pannel,then, sound/audio setings and see if everythings set up properly
Sep 19, 2011 | Lexicon Lambda Usb Desktop Recording...
Window show (No Audio Output Device is installed)
1. Make sure your Microphone is connected properly to the correct port (It's usually the one with the little mic picture on it at the back of your CPU)
2. Once it is properly connected, the system will automatically detect your microphone and suggest for you to download the necessary drivers needed. Do so to fully use your device.
3. If this still doesn't work, go to control panel, click on sounds and make sure that everything is set up properly (audio, mic in has volume, etc)
Jun 14, 2011 | Computers & Internet
Driver installs ok and detection also but no sound.i have try to put also in the volume control the sound getting out from behringer.doesn t work
"No Active Mixer Device installed".....The Sound and Audio issue of Windows.....the infamous issue being faced by many PC/Laptop/Notebook users all over the world....on clicking the volume control icon in the task bar near the clock.....or....Sound and Audio Devices Grayed Out in the Control Panel
Guys....the solution's very simple....This is a sure shot solution...101% guarantee...Just do this...
Go to Device Manager, select Sound, Audio and Games Ctlr expand (+) press the plus sign, go one by one on all those that show a speaker each one by one and right click, and if it has the "uninstall" option...just uninstall. Dont do anything further....just shut down pc/laptop
Then...u need to go into system BIOS
1 - Start PC/ DEL or F1/F2/Insert/Home key...this selection of key to go into BIOS depends upon ur type of PC in some Del key works in some F1/F2 key works to go into need to do this before the WindowsXP screen appears....get into BIOS...
2 - Scroll/go to On Board screen....
3 Look for
A- "On Board audio"
B- "AC97 audio" or any thing that says "Audio"
C- "Look for anything that says "MIDI" with some numbers 301,205 etc in [ ]
just Disable all the above by using PgUP PGDN key Press F10 and chose Yes to save the setting in BIOS or use Save and Exit in BIOS
Let WinXP load...go to Device Manager...go to Sound Audio and Games Controller...check all those that you uninstalled earlier if they RE-Appear...It should NOT......Re-appear.....if it does then do the above process once more.
U are now all set for the next move....
U need to spend just 1$ to buy this product on can buy any similar product of your choice but it must have the audio and mic output ports like this one has...and must be able to connect to your USB port of your PC/Laptop
This below image and product name is only for your info, you can buy any such similar product available in your area....but it's must have the Audio and Mic output ports like the one on the image below and must be able to connect to your PC/Laptops USB ports...
"USB 2.0 Mic Speaker 5.1 Audio Sound Card ADAPTER #9340"
You can Google it and locate it where you can buy...
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...01be335.png
Nov 03, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
Hello friends Iam also having same problem with my c772 laptop . I have sound working but mic is not .. I think it needs different audio driver that could enable mic and audio .. thanks
The mic output on the ua-4fx only supplies 5mA of power. If your mic reqires more than that, then it won't work. Consider an external mic preamp.
Jul 01, 2009 | Edirol UA-4FX External Sound System
Try a different set of headphone, if it works, then it is the headphone set.
If you get same problem with all headphones, then
If you get no sound: ensure that you have sound from speaker, if you get sound from speakers and no headphone working, then there is a problem in the headphone connection.
If you have no sound at all , not even with speakers, then check audio settings in control panel, ensure audio is not muted. If audio settings are OK, then you need to reinstall audio driver, or you have a faulty audio card.
Additionally, if it is only the mic not working then do the following:
Go to control panel and open sound and audio device.
Open volume settings and find settings for mic.
Tick off the mute option.
The mic is muted by default in Windows, that is usually the reason why it is not working.
Sep 14, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e.
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Mic doesn work
same thing happened to me, it wouldn't even work when i went to control panel -> audio devices -> mic test   i think i'm just going to return it for a different model.
headphones worked well though
Sep 23, 2007 | Logitech Premium Headset
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
