Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Alarm I have a Campaq SR1000. When i turn it on i get a continuous alarm, and the system will not boot up. I have disconnected all the leads, and [pluged them in agian and still i am getting an allarm, if you just plug in the power cable and try to switch it on on you still get the alarm. Any ideans of how to fix the problem
When i remove P7 power supply jack the heat sink fan will run and when i install P7 jack the fan will not run the whole system goes dead
Posted on Dec 26, 2008
    Brigadier General:
  • 5,158 Answers
That does sound like a memory issue. remove the memory and reinstall it to make sure it is seated properly.
Robert
Posted on Sep 06, 2008
HOW DO I DISCONNECT MY 1987 TOYOTA SUPRA ALARM SYSTEM
Why? I would not start messing with a factory ubit. It's highly recommended to leave it alone. I have 2 alarms on my car without any problems, the ford alarm can be integrated without any problems. Thos e factory alarms are a major part of your wiring system and can lead to a very big problem if you start changing them. And that leads me to ask why would you want to disconnect it in the first place? If it's acting up then look at the fuses and make sure they are all good and making good contact on the prongs. Make sure that all sensor contections are clean and plugged in completely making contact.
Oct 29, 2014 | Cars & Trucks
I have a 05 plate coupe 2ltr se, can't turn immobiliser/alarm off with fobs, both fobs have new batteries and have ben sync'ed with car as per handbook, could it be a fault with body unit
This is a long shot but worth trying as it is free:
Disconnect both leads from the battery, contact the two removed leads together (this will diffuse the ECU memory and re-boot the system)
leave for a few minutes then reconnect.
(The above can lose a radio code if applicable)
This can reconfiger the systems and sort out a multitude of issues.
Hope it sorts it out for you.
Feb 16, 2012 | Cars & Trucks
I accidentally locked myself out of my Smarthhome Securelinc Alarm Installer Code Model OH-41073AT. I would like to reset the unit to my installer code or create a new one. Can you assist?
The first thing to try would be to disconnect the mains supply and remove the internal battery for a minimum of 5 minutes and then reconnect it.
If this doesn't reset the system then remove the mains supply and battery again for another 5 minutes.
After 5 minutes reconnect the battery.
Then with the help of a friend try holding the # & * keys while they turn the mains supply back on.
These are generic resets for most house alarms but I'll keep looking if there's a specific one for your system so if neither of these work just let me know.
If I find anything else in the mean time I'll add to this post.
Jul 06, 2011 | Visonic INC Smarthome SecureLinc Wireless...
My s class 2004 mercedes wont lock. I try to lock it from the inside, it doesn't work. I press the remote, the light flashes, but it doesn't lock. When I drive; the doors doesn't lock like usual. The...
hi, if any doors, boot or bonnet is open it will not lock. there are SWITCHES that has to be set.for the system to recognize it is closed. please check all openings even windows. ONLY DO THIS IF.if the BATTERY HAS BEEN TAKEN OFF OR BATTERY HAS BEEN DISCONNECTED. the SYSTEM MAY NEED RESETTING. the battery NEGATIVE lead needs to be taken OFF and place the NEGATIVE LEAD ON THE TERMINAL (A NOISE WILL BE HEARD), the ALARM and CENTRAL LOCKING SHOULD BE RESET, if the ALARM DO'NT SOUND put the lead ON and OFF a FEW TIMES. CLAMP THE BATTERY LEAD CONNECTION TIGHT and press the ALARM BUTTON OFF and retry locking SYSTEM. this will work if everything is O. K. gerry
Sep 13, 2010 | 2004 Mercedes-Benz Mercedes Benz S Class
1995 Jeep Grand cherokee limited V8, Won't start. engine cranks just fine, good battery. 12+volts to the coil. Doesn't seem to have any pressure in fuel rail after cranking. Picked up jeep yesterday...
hi, this could be you have not reset the ALARM, when you toke the battery off. please undo the NAGATIVE lead OFF the BATTERY and hold the battery lead ON (for 2 seconds) then take battery lead OFF. you will hear the ALARM make a funny noise (this resets the alarm), put the battery lead ON again and the alarm should SOUND then tighten the NEGATIVE LEAD TO THE BATTERY. if not you need to get the ALARM TO SOUND, need to undo battery NEGATIVE and do the same as above. there is a knack to it. then this will work. THE SYSTEM IS LIKE THIS FOR SECURITY RESONS. gerry
Sep 11, 2010 | 1995 Jeep Grand Cherokee
I engaged the alarm on my 2001 Fat Boy and the
i'm no expert on new Hogs but try this.In car alarms disconnecting the neg.lead resets the computer.when you reconnect the neg.lead the alarm goes off.In your case turn the alarm off by turning the key on.Your alarm light keeps blinking like it's still on because it is.The blinking and ticking should time out so your battery won't go dead but the anti theft feature should still work.locks out the ign. or locks fuel pump if your injected.Since your battery saver doesn't work the system might be shot.If you have a chip in the key the system may not recognize it ,doesn't know it's you.Try unlocking the bike with the remote if it has one.I vote for the bad system,pull it out an wire around it.Good luck.
Mar 18, 2010 | 2000 Harley Davidson FLSTF Fat boy
Disarm car alarm
Simply disconnect the power leads to the alarm...........sodeep
May 11, 2009 | Vehicle Parts & Accessories
Alarm system
see the boot switch wire lead to alarm unite and unplug wires from it, or diconnect the fuesed wire to positive battery.
Nov 16, 2008 | 1993 Saab 900
My security system continues to sound when you open up the locked door.
I have a 1992 Acura Legend. If the alarm goes off when you open the door when the alarm is set you may have to close the door and put the key in the door lock and turn it clockwise to turn the alarm off.
Jul 25, 2008 | 1992 Acura Legend
Alarm
your video card has gone bad, replace and all will work again
May 12, 2008 | Compaq Presario SR1000T (568657) PC...
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
118 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
