Question about MicroVision Development HS2121-MV
The problem with reading the barcode
1. The barcode was scanned with the reader 2. Information was downloaded to the computer. 3. In computer we see completely different number. Same happens with all 4 readers that we have in stock. We used them before and there were no problems. We do not have that problem, if we use other readers. 1.Is there a software in the reader, which should be updated? Company Name: Trader's Forum Tel: 905-760-7694 email: alex@tradersforum.ca Contact Name: Alex
    Novelist:
    Champion:
  • 277 Answers
Be sure the Flic scanner is set to the factory default configuration by scanning the Defaults bar code given above. Then check the Format options for Characters to Strip and Characters to Append (see page 10) and make sure these are set correctly. In order to scan the ?Factory Defaults? bar code in the Flic Operator?s Guide to reset your Flic scanner to the default settings: Select Flicware , Tools , Format and add the appropriate control character(s) in the Characters to Append box. Good luck.
Posted on Dec 05, 2005
Why doesn't it scan?
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
Jan 27, 2016 | Zebra Symbol LS4278, Bluetooth, Blood Bank...
Tip
How do I read barcodes from an Adobe PDF FILE?
<p>Reading a bar code in a portable document format (PDF) document is a simple procedure. Some newer phones come with smart barcode scanners, and you can scan the Internet to buy. A barcode is a series of lines of code that identifies a product. When you print the document with a single piece of technology, you can read a barcode in a PDF document. <br /> <p><br /> <p>1. Open the PDF document. Adobe Reader PDF reader is the most common. If you do not have Adobe, download the latest version of the company's website for free download (see Resources). <br /> <p><br /> <p>2. Select "File" drop-down box to the left of Adobe. Select "Print" and then "OK". <br /> <p><br /> <p>3. Set the bar code scanner. Jumping the gun and a horizontal red line is designed with the focus of the scanner. Move the line through the barcode printed on the document until the scanner beeps. Release the trigger and see the screen on the back of the scanner, which will give you the information encoded in bar code. <br /> <p><br /> <p>4. Download a barcode scanning application for your smart phone if you do not want a handheld scanner. Most bar code applications are free. Open the program and point the camera at the barcode in the PDF. Wait until the camera for a snapshot of the barcode will not make up the barcode in the light of the entire camera to take. The program will decode the barcode and display the results. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
Why i cannot scan 1 digit number
Did you make the barcodes using Code 39 or 3 of 9? If so, the scanner defaults to reading between 2 and 55 character Code 39 barcodes. Go to the Motorola Solutions support portal and search for Article ADC-00404 portal motorolasolutions com. Print the article and scan the Code 39 Any Length barcode. Once this is done the scanner will read all Code 39 barcodes.
Aug 12, 2014 | Symbol LS 4278 Barcode Scanner
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
Tip
How to install a barcode
<p>Bar codes are images that data can be scanned and read by computers and other devices contain. They usually appear on the packaging as black lines that are scanned when you buy the products, but they can come in various shapes and used for many different purposes. Creating a bar code means to make the image bar code using special software, prints it and attaches it to the relevant item. <br /> <p><br /> <p>1. Surfing the Internet for sites that offer free services for creating barcodes (see Resources). <br /> <p><br /> <p>2. Open the Web page Most of these sites offer the ability to create different types of barcodes. If so, select the one you want by clicking on it. <br /> <p><br /> <p>3. Type the information that is encoded in a barcode field or space provided. Look for a button or link to the bar code and click generate. See the image of the barcode that results when displayed. Right-click the image to the browser's drop down menu and select "Save Image As" to save the image on your computer. <br /> <p><br /> <p>4. Open the barcode image and printing the image using sticky paper. Connecting a bar code scanner to the serial port or USB port of your computer and scan the bar code printed. Check the information sent to your computer to verify its accuracy. Cut out the barcode labels remove the patch and attach it to the item or product. <br />
Motorola MC5590 is not able to scan barcode
download the datawedge file for the mc55. Its probably not loaded and configured. Once you have this file on the device and you need additional information please let me know
Here is the version 3.1.7
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12465&sliceId=&dialogID=162320658&stateId=1%200%20162316370
kganoe@datexcorp.com
Mar 25, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Scanner shows number but won't scan to computer
If you're sure that the barcode is correct then ignore the following.
Otherwise, download a free barcode font and install.
1. Open up wordpad .. and type any number say "12345", and then convert it by choosing the barcode font.
2. Print out the barcode (usually at least 26pt)
3. Leave wordpad as the active window and scan the barcode
4. "12345" should be inserted into the wordpad document.
Now you know that it works.
This should work on the default setting of most scanners.
Mar 21, 2009 | Computers & Internet
VB With MC9090S
If you are willing to use VB.NET, then it will be easy. You would need the Symbol EMDK. With that and VS2008 (Express should be fine as well), you only need few coding steps:
1) Add reference to dlls
Symbol.dll and Symbol.Barcode.Dll
2) Finder a scanner
s = Symbol.Barcode.Device.AvailableDevices.First()
3) make a reader
r = New Symbol.Barcode.Reader(s)
4) add data
d = New Symbol.Barcode.ReaderData(1, 1024)
5) enable laser
r.Actions.Enable()
6) enable reading
r.Actions.Read(nrd)
7) add handler
AddHandler r.ReadNotify, AddressOf r_ReadNotify
8) read data in event
msgbox(d.Text)
That is all there is too it. Good day.
Jan 22, 2009 | Symbol MC9090 Barcode Scanner
MicroVision Development HS2121-MV Logo
308 people viewed this question
Top MicroVision Computers & Internet Experts
Alun Cox
k24674
Are you a MicroVision Computer and Internet Expert? Answer questions, earn points and help others
