Question about Sanyo PLV-Z2 Multimedia Projector
Changing bulb we've changed our bulb in our sanyo projector and now the projector is not receiving a signal
    Master:
  • 497 Answers
Upon setting up your equipment it is very important that you turn on the projector first. You will see a blank projection image, now turn on the computer, (confirm your cables are connected properly). When using a lap top computer you may need to disable your computer's display screen. First locate the "function" key at the top of your keypad that reads "LCD", "CRT" or it may have an icon that resembles a computer monitor. By pressing the "FN" key and the corresponding "function" key you will be able to obtain the image from the projector only. This is known as "toggling" the image.
for more info check this link http://www.avispl.com/service-support/projector-troubleshooting.asp#2
Posted on Sep 06, 2008
Sanyo projector i change the bulb but it wont start up the bulb how to reset?
http://www.google.com.et/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CBsQFjAA&url=http%3A%2F%2Fforums.cnet.com%2F7723-13973_102-398100%2Fdlp-twon-t-turn-on-blinking-green-lamp-light-then-shuts-dow%2F&ei=-VnbU_8Hg9XRBeWdgIgM&usg=AFQjCNGp5RYvSkK-2YKIqjHeH2oxVnzU-Q&bvm=bv.72197243,d.ZGU
Aug 01, 2014 | Sanyo Xga 4500 Ansi Projector
I have a Sanyo plc-xt25 LCD Projector and when I plug my ac cord in, the fans turn on but no lamp comes on. I changed the lamp and still no picture. What do I do?
Every projector lamp is equipped with ballast. The problem area is ballast. Either the ballast is not getting DC supply or the lamp turn ON signal from the projector main board or the ballast is faulty. Remove the lamp. Connect the projector to the mains supply. Check the voltage at the lamp connector inside the projector without turning it ON. It should be around 65 volts A/C. (Warning: Multimeter will get damaged if the projector power is turned ON due to generation of high voltage) If you find this 65 volts then it confirms that it has DC supply & the ballast is functioning. The ballast receives the the turn ON signal from microcontroller through opto-coupler on the ballast. The ballast opto-coupler can be checked by providing external 5V DC supply between pin 3 (+ve) & 4 (-ve) in turn switches ON the lamp. If this works then there is no problem with your lamp & ballast. The problem lies with the main board. If this does not solve your problem then give me the feedback.
Aug 04, 2011 | Sanyo PLC-XT25 LCD Projector
Not receiving signal from computer (checked cable & setting)
1) make sure you are not plugged into the "analog out" port on the projector.
2) check the cable for bent or missing pins (there should be 15)
3) try changing the resolution on your computer...1024x768 is safest.
Feb 18, 2011 | Sanyo PLCWM4500L PROF PROJECTOR Projector...
Im using sanyo pdg-dsu21b model. right now, my projector has this little white bright spot all over the projection. can anyone please tell me whats the problem with my projector and what is the solution...
Unplug you projector and allow the bulb to cool. Open the area where the projector bulb is located. Check the projector lens for any damage and clean it from dirt's and dust. Same as with the bulb.
Nov 09, 2010 | Sanyo PDGDSU21E DLP Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
How do i change the bulb in a sanyo pro xtrax multiverse plc-xu30 prodjector
remove the screw on the door on the bottom of the projector for the lamp and pull out the old bulb and replace
Apr 16, 2009 | Sanyo PLC XU30 Multimedia Projector
Sanyo projector PLV-70 color lenses fell out when changing bulb.
Trial and error---putting them in each different slot until we got it right))..pain in the ****!! :-)
Jan 29, 2009 | Sanyo PLV 70 Multimedia Projector
PROJECTOR POWERS DOWN
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
Jan 18, 2008 | Sanyo PLC XU50 Multimedia Projector
Sanyo PLV-Z2 Multimedia Projector Logo
167 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
