Question about Compaq Presario 700 470024-192 Notebook
Mic and headphone problems
I am unable to off the speaker volume when iconnect my headphone.........
i am unable to use my mic during a call
  • 6 more comments
  • Anonymous Sep 06, 2008
    head phones
  • dmaddy Sep 06, 2008
    i am unable to off the speaker volume when iconnect my headphone.........
  • Anonymous Sep 07, 2008
    i am unable to off the speaker volume when i connect my headphone.
  • Anonymous Sep 09, 2008
    my internal mic is working fine...but the external headphone and mic are not working! wat 2 do...someone plzzzzzzzzzzzzz help
  • iksoft Sep 09, 2008
    i have c785tu notebook my inetrnal and external mic is not working on windows xp as well as headphone also not working
  • Anonymous Oct 01, 2008
    i dond listen to suond in my sistem
    when i connect microphone then sound comes from speaker &headphone simultanusly.
  • prasanthjnth Feb 05, 2009
    Thanks a lot my problem got solved with ur suggestion
    Novelist:
  • 130 Answers
Hello Guys,
The issue you are facing is due to the incompatability of the audio drivers on the notebook.
Follow the below steps:
Uninstall current audio driver form the notebook.
Then downlod the audio driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Audio%20driver.zip
After downloading the file please extract the files to a folder on the desktop.
Follow the below steps to install the driver correctly:
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select not at this time, click on next and Select "Install from a list or specific location".
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse, Choose the location where you have saved the extracted folder.
8. Open the folder and choose the .inf file listed.
9. Ignore any errors you receive and proceed with the installation.
Posted on Sep 10, 2008
Headphone pluged in does not cut off speaker in toshiba laptop
Headphone socket is possibly faulty or you are plugged into the mic socket or there is a separate volume control to drive the speakers or the driver is not installed correctly.
Dec 05, 2013 | Computers & Internet
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
How can i increase volume for mic iphone 3gs or input volume during calls..they cant hear me clearly..thats my phone problem..iphone 3gs..
Hello
1 .You need to confirm if its the volume or the mic of your phone that has the problem.
2 .If its the mic,your callers would not hear you but you would be able to hear them.
3. You can Adjust the volume of your iPhone by depressing the volume button on the left edge of the phone, close to the top. This will cause a volume indicator to appear, superimposed over the other icons on your screen. This will increase the volume of your ringer. If you wish to adjust the volume of the phone speaker, use this button during a live phone call. You can also control the volume of your speaker when you are using your iPhone as a music player in the same manner.
4. If its the mic,remove the iPhone from the case, as your case may be blocking the device's microphone.
5. Plug the iPhone device cable into the iPhone and into the computer's USB port.
6.Launch iTunes. Click "iPhone" or the device's name in the sidebar in iTunes and click "Summary then Click "Check for Update" and "Download and Install" to update your iPhone's OS.
7. Remove the device cable after the update finishes and insert your headphone jack into the iPhone's headphones port,tap "Phone" on the home screen, tap "Contacts" and tap a contact to place a call.
8. Press the "+" button on the microphone to increase your microphone's volume.
9. If the problem persists take your iPhone to your local Apple Store for professional service.
BEST OF LUCK
Dec 15, 2010 | Cell Phones
My problem is when I'm recording my voice and or just using my webcam I get a loud background noise, I didn't have this problem until maybe a week into having my webcam, can you please help me?
Make sure the webcam mic is set as default - especially if its a laptop which also has a mic.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Your mic may also be picking up sound from your own speakers. To overcome this problem use a set of headphones.
Aug 12, 2010 | Logitech QuickCam Messenger Web Camera
Everything seems to be working, but the audio has a lot of noise when playing back? Robert
1) Make sure your webcam mic is set as default
Vista
TEST SPEAKERS
Restart computer
2) During the recording you may be picking up feedback from your speakers - try using a set of headphones
Jun 22, 2010 | Microsoft LifeCam VX-3000 Web Camera
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
No sound
You may have a laptop with a built in mic or headphones with built in mic and webcam with built in mic
You need to set your webcam mic as default
Vista
TEST SPEAKERS
Restart computer
Configure to your chat program
May 23, 2010 | Logitech QuickCam Deluxe for Notebooks
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
Mic
Try a different set of headphone, if it works, then it is the headphone set.
If you get same problem with all headphones, then
If you get no sound: ensure that you have sound from speaker, if you get sound from speakers and no headphone working, then there is a problem in the headphone connection.
If you have no sound at all , not even with speakers, then check audio settings in control panel, ensure audio is not muted. If audio settings are OK, then you need to reinstall audio driver, or you have a faulty audio card.
Additionally, if it is only the mic not working then do the following:
Go to control panel and open sound and audio device.
Open volume settings and find settings for mic.
Tick off the mute option.
The mic is muted by default in Windows, that is usually the reason why it is not working.
Sep 14, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone and headphone problem
Usually when you double click the speaker icon in the system tray you'll see the volume settings for all your devices. On microphone there is usually an check box for mic boost. Set those to mic boost. Then check that all the sliders in the volumes are one increment below the top but maximum for Wave. Then set the master volume to a comfortable loudness This you can access by a single click to the speaker icon.
Next, you can go to Control Box, click on Sounds and check the settings for speakers/headphone and also for recording where there is usually a routine for checking the recording settings via your microphone made available to you.
Please do not hesitate to ask me for more information and kindly be specific if you can. I'm here to help and will get back to you in a reasonable period of time.
Hope this fixed your problem and thanks for using Fixya.
Regards,
Worldvet
May 26, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
