Question about Sony KDS-R60XBR2 Television
Sony kds-r60xbr2 televison
Their is a green on the picture
  • 2 more comments
  • vicp1955 Sep 06, 2008
    thier is a green HUE on the picture
    my speakers have been near the tv for about 2 years
    I moved them away and still a green hue
    Changed blub about 6 months ago
    tried your solution it didn't work
    the darker colors seem fine the lighter colors take on a green hue.
    if you can give me a cause of this problem i can relay it to
    the sony repairman
    thank you for your time
    the solution didn't work looks like i'll need a sony repairman
    thank you anyway
  • 10,594 Answers
Problem is adjustment of service data in your TV and please forward below technical information to Sony repairman, he can understand and can perform accordingly...
3-1-4. REGISTRATION ADJUSTMENT
1. Set the service mode to DEM.
2. Display the crosshatch of Test Pattern (see below 1)).
3. Observe the crosshatch, in case of finding out the color is out
of order up or down/right or left, adjust its registration of color
(see below 2)).
R, G, B colors can be adjusted separately.
Note: Don't shift the green.
Adjust the red or blue color to green.
Adjusting color shifts up or down/right or left entirely on the
screen.
Adjustable range: Up or down; 1 ± 1 line
Right or left; 2 ± 2 dots
1) Crosshatch Pattern Displaying Procedure
• Select '5 TEST_PAT' in PANEL service menu.
• Select '2 PAT_ENB' in its sub menu and set the data 0 to 1.
• Select '4 MODE' in its sub menu and set the data 0 to 4.
The crosshatch pattern appears on the screen.
2) Shifting Procedure
[Up or Down]
• Select '1 TG' in PANEL service menu.
• Select '25 VSFT_R' (shifting Red) or '27 VSFT_B' (shifting
Blue) in its sub menu and set the data 0, 1 or 2 to the best.
(Center value: 1)
[Right or Left]
• Confirm '0 H_SHIFT' data is 0 in its sub menu.
• Select '1 HSIFTR' (shifting Red) or '3 HSIFTB' (shifting
Blue) in its sub menu and set the data 0, 1, 2, 3 or 4 to the best.
(Center value: 2)
Thats all and above info are based on concern Service Manual.
Regards,
Posted on Sep 06, 2008
  • Shahid Electronics
    Shahid Electronics Sep 06, 2008
    To all experts in this thread...
    Sony KDS-R60XBR2 is SXRD 1 Lens Projection TV and it is not old style 3 CRT rear projection and it has nothing to do with magnetic field distortion in colors. Below is TV specifications for your knowledge...
    Projection system
    3 SXRD panel, 1 lens projection system
    SXRD panel
    0.61 inch SXRD panel 6,220,800 pixels (2,073,600 × 3)
    Projection lens
    High performance, large diameter hybrid lens F2.5
    Lamp
    Ultra High Pressure Lamp, 180 W, XL-X5300
    Regards,
    Master:
  • 638 Answers
Convergence problem.
    Genius:
  • 1,269 Answers
The red bulb is out. All TV's have three bulbs, red, yellow, and blue. Since only the yellow and blue bulbs are working, you are getting a green hue. You can try calling around tv repair shops and getting a quote. Depending on what kind of tv you have, it may be cheaper to replace the tv instead of the bulb. The problem is that it either needs degaussing or the color purity is off.
Most TVs have an automatic degaussing circuit. If you unplug it for several hours (3-5 hours), then plug it back in and turn it on, it should degauss automatically.
If that does not work, some of them have advanced digital adjustments, that you can work from the TV Menu and do the degaussing there.
If one of the electron guns is not working, you need a new picture tube or a TV repairman, probably cheaper to replace it.
  • 185 Answers
Sir,
You have this problem
1.due to the cable,check the cable behind the tv make sure that the cable is not damaged. If the damage is available then replace the cable with the help of service engineer.
2.Check the ICs on the TV board with the service engineer.
  • 1,879 Answers
Two things you can do
>check the color settings
>reseat the lamp
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
    Sergeant:
  • 264 Answers
Make sure that you do not have a magnetichc feild around the TV.
  • Sameer Kashyap Sep 06, 2008
    By Magnetic field i mean there should not be any gadget near the TV which contains a heavy Magnet. It may continuously create a magnetic
    field which will surely create this kind of issue
    Turn off the power of the TV. Press and hold the power button for 20 seconds on the TV(It wont show anything).
    Than turn it on again and check.
    That is known as powercycle
KDS-R60XBR2 No picture, no sound but solid green light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Power error 6 times - 11V is low. - No picture/No sound
From my past experience, yes. Not sure about the 11v being low. My kdf 45 acted that way when the main lamp went out. Found a replacement on Amazon for around $45 and now good to go! So far about a year and a half. Have had to replace about 4 for friends and family so far with same symptoms. All worked great! http://www.amazon.com/F93087600-Projection-Replacement-KDS-R50XBR1-KDS-R60XBR1/dp/B005I4OLAS/ref=sr_1_13?ie=UTF8&qid=1386773721&sr=8-13&keywords=Sony+Sony+Kds-r60xbr2+bulb&tag=donations09-20
Dec 11, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Green haze on picture at all times.
High voltage in your green cathode.maybe loose connection or deffective color transistor driver.
Oct 06, 2010 | Sony KDS-R60XBR2 Television
Picture color is off after circuit breaker tripped. Only blues and greens. Model SONY KDS - R60XBR2. Does the lamp do this when it needs replacing or could something else have blown when the breaker...
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 26, 2010 | Sony KDS-R60XBR2 Television
KDS-R60XBR2 projection 60'' Sony tv the picture is turning yellow why is this happening
It sems that you are having a problem with you color wheel, that is what makes the variation of color happen in your tv set, if that is not working correctly, it causes either a black and white picture, some times no picture at all or like in your case to much of one color.
Jul 20, 2010 | Sony KDS-R60XBR2 Television
Projection sony tv is yellow
Most likely it is the Optical Block. It has been a issue for most of the Sony LCD Rear Projections manufactured over the last 6 plus years. Your Model may still Qualify as a factory recall. What you need to do is to get in touch with Sony's Customer Service at 1800-222-SONY and see if it does Qualify.
If not, it is a expensive repair costing 1200.00 to a 1500.00.
I hope it still does Qualify for a recall,
Skyassoc
Jan 07, 2010 | Sony KDS-R60XBR2 Television
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Green Smear
It sounds like your optical block has failed. If you can see the picture but it has a green smear through the picture, this is likely the problem. Sony has extended the warranty on the optical block and is covering parts and labor for the repair. Contact Sony at 800-222-SONY to schedule a tech to look at the TV and replace the optical block
Jan 01, 2008 | Sony KDS-R60XBR2 Television
Sony KDS-R60XBR2 Television Logo
335 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
