Question about Brother HL-2040 Laser Printer
Brother HL2040 PRINTING DOTS
Have just changed the toner - did everything correctly - but now the printer is printing 2 dots and 1/2 intervals down right hand side of page. checked the blue tab position for corona wire clean is in correct position - anyone know what else I can do?
    New Friend:
  • 159 Answers
1- change the drum unit
2- check the fuser unit
Posted on Sep 06, 2008
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
Pages have black dots and smudgy. In the booklet
You have a laser printer, so a prime and clean of the heads is impossible since there are no heads. I can only assume that you want to clean a few inside parts to solve your problem. You can do some light cleaning with the little brush located just inside the panel as you open your toner drawer, but this will not solve your problem either. Black dots and smudge are usually caused by a too moist environment, or from being placed too near an Air Conditioner vent.
Remember that your printer works by heat transfer and your laser. fuser and drum become quite hot. In a humid area such as a kitchen, this can mean that the drum will condense as it cools. This may also happen if it cools too quickly due to being placed near an AC duct or window AC. To solve your problem, move the printer to an area with no coffee pots, vaporizers, or other moisture producing appliances and do a warm up several times then a shut down to dissipate any moisture. Now remove the toner cartridge and shake it lightly side to side, taking care not to tip the toner cartridge on its end or turning it sideways. This will redistribute the toner evenly across the cartridge.
Reinsert the toner, and try printing a test page.
Remember that the drum is the hottest part of your printer, so take care not to touch it.
Here is a photo detailing the primary parts of a basic laser printer for your reference.
http://i22.photobucket.com/albums/b312/HizHoz/laser-printer-path.gif
Mar 10, 2010 | Brother HL-2040 Laser Printer
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Jan 11, 2010 | Kyocera FS-3900DN Laser Printer
Three dots on right hand side
pls replace the toner because it is a toner problem.
Sep 17, 2009 | Brother HL 1440 Laser Printer
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Dots when Printing
Replace toner then you cam make sure wether problem with toner or printer.
May 22, 2008 | HP LaserJet 1020 Printer
Printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Apr 01, 2008 | Brother HL 1440 Laser Printer
Brother laser printer printout
You need to clean your drum unit:
see http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001044&Sympt=The+print+jobs+have+black+spots+or+black+dots.+How+can+I+improve+the+print+quality%3f&Model=3&ProductGroup=1&Keyword=dot&ProductID=HL2040
Worked for me!!
Dec 19, 2007 | Office Equipment & Supplies
Brother HL-2040 Laser Printer Logo
249 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
