CD player will not read disc. CD is inserted, begins spinning, laser trys to read three times and then goes onto next disc. Will not read all three - and waits for me to change the discs.
The laser lens in your CD might be dirty or failing.
Try the following solutions:
Clean the laser lens with a DVD player lense cleaning disc.
Lense cleaning discs are available at many electronics retail store.
Sorry i can't help you more.
This is very common as unfortunately the quality of the CD player means they rarely last as long as the the rest of the unit. Sometimes it is just dust on the laser lens and being at the bottom of the unit they will collect any dust that falls from above and the lens isn't easy to clean.
If you load a CD and hear it beginning to spin and the onscreen message indicates it is trying to read the disc but eventually fails and stops - it is probably either dust or a poor laser.
Both are a dismantling job and a replacement laser requires a professional - consequently people tend to consign them to garage sales and move onto the next hifi.
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Hello Insert a lens cleaning disc into the system, and play it at least three times, by eject it out and reinsert in each time. If it does not help you, the laser pickup unit of your Cd player should be replaced with same type and number. OK.
Hello Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
Hello If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number. If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Hello
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
