Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
  • 3 more comments
  • Anonymous Mar 21, 2009
    I have the same problem = Code Error 0F00 - 065D when I run the diagnostic self-test. I have a Dell Vostro 1710 Laptop. However, I can run the Window for few minutes, and then cannot use it anymore. It goes: Window Explorer (not responding).
    Any advice how to solve it?
    Thanks
  • jamesneasham May 09, 2009
    When i tried to load my computer a blue message flashed up and said that there has been some hardware installed improperly on my computer so it had to be shut down to prevent damage to the system. When I performed a test the following error codes flashed up:
    Error Code 0F00:065D
    Msg: IDE device failed: The self-test failed the read portion of the test.
    Then when I continued the test the following error code flashed up:
    Error Code 0F00:137B
    Msg: device failed: Blank media or no media is present in optical drive. Test requires media with data (Resource CD, Installation CD).
    If anyone can help, that will be much appreciated.
  • heyyyy Jul 28, 2013
    Buy new Harddrive
    Buy new harddrive
  • Dustin Larmore
    Dustin Larmore Jul 01, 2014
    dell inspiron n4110 error code 2000-01 42 Validation 51532 Msg: Hard Drive 0 - S/N WD-WXM1A61M4533
Its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Posted on Aug 11, 2009
  • 1 more comment
  • mkgmaccount Aug 11, 2009
    and on point 10, press enter after all:
    c:\chkdsk c: <- and press enter
    And remember in future to change your hdd, because these kind of problems menas that is going to hard drive heaven
  • e5frog
    e5frog Aug 05, 2012
    "c:\chkdsk c: \f" if you want the chkdsk to also fix the errors it finds.
    Sergeant:
  • 320 Answers
The error code says that "Windows will not boot, Not even in safe mode". Am i right...
Get a new Hard drive(HDD) and connect it to your pc and load the Windows Operating System. Or again try installing a new copy of Windows to same hard drive. Hopefully it should work.
Or else do one thing . First you do this - Go to BIOS setup. To do this restart your PC and keep on pressing the del key or F8 key. The system will automatically goes to BIOS mode. change the configuration settings i.e., disable storage devise. If it's enabled then your pc will not detect Hard drive. Thank you
Posted on Sep 06, 2008
I have a dell 1735 laptop windows vista premium. the consumer IR devices won't load. I'm in safe mode and the device status says:- this device is not working properly becuase windows cannot load the drivers required for this device (code 31)
Also did a device self test (short) and the result was fail error code 0f00:065d msg disk - dst self-test read error. i need help as my computer isnt even a year old
Posted on Dec 05, 2009
Error code; 00f00:136c IDE device failed; Blank or no media is present in optical drive. Front panel audio and flex bay cable: not installed Onboard or USB floppy drive (not present) Onboard IDE hard...
the diagnostic was looking for media in the CD drive during the test. If the drive works in Windows and reads media or you can boot to the CD drive, then there is nothing wrong.
Jan 07, 2011 | Dell Dimension E310 PC Desktop
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
I have a Dell Inspriron B130 laptop computer. I
Dear,
This is a clear hard drive issue. Try reinstalling Operating System, If it fails again, probably you have to replace the hard drive
Oct 15, 2009 | Dell Inspiron B130 Notebook
Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Sep 07, 2009 | Dell Dimension 3100 PC Desktop
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Dell Inspiron 1420 freeze at starting
This is an easy one.
You hard drive has DIED.
Call or chat with Dell tech support and get a replacement drive
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&l=en&s=gen
Since the system is less that a year old, you can request a replacement drive witht eh factory image on it too.
Jul 14, 2008 | Dell Inspiron 1150 Notebook
Dell Latitude d600 Laptop comp_ Error code 0f00: 136c
I think its your harddrive mate,, it might not be connected propperly or its dead, look at the connection and ensure its connected, if it is connected correctly, you may need to change it..
Jan 12, 2008 | Microsoft Windows XP Home Edition
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
28,561 people viewed this question
David Payne
David Payne
