Question about Whirlpool Refrigerators
Whirlpool fridge Model # ed5ftgxkq freezer wont freze
I am not an expert but I have the same fridge and came across this information concerning the same model:
You have a bad overload / relay , which is plugged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 2220477 , and is easily replaceable .
Posted on Jan 25, 2010
I hear a clicking sound and my refrigerator side is starting to get warm. What should I do
Posted on Mar 26, 2010
FRIDGE/FREEZER KEEPS FREZING UP
Did you check or replace the defrost timer? It could be a solid state type built onto a Printed Circuit board or could be a timer motor, it all depends on the model and make of the freezer.
Apr 10, 2008 | Refrigerators
My haier mini fridge is frezing everything and i have it on its lowest thermostat setting what is wrong with it
just a suggestion: but you might have to much coolent in it, or its useing alot of power,maybe too much power and the fan is spinning at a high rate,IDK maybe thats it.it probably wont help you though
PS:maybe take it to a shop
Jun 08, 2012 | Haier Refrigerators
Whirlpool Refridgerator Model # ET1FTKXKQ00 My Question: I can not seem to locate the hose that would take the moisture from the freezer/fridge to the evaporation tray at the bottom. My fridge is...
Hey i think they freze free lol and thers no tubes they are connected by chanels/ tunels blockes at the back fron freezer down. Reg temp yr nobe controler could b gone or temp module. So thats why it wont help lol check if the temp changes after yr turning it, so atleast u can iluminate that.. if it is working. Than i would sugest next checking yr front doors rubers and magnets on them all the way and both doors.. as wen it gets old it could b having gaps so there 4 it will not close the dore properly and u wont even know or notice and if thats the case. Thats why it running inside, as it not fully and all aront germeticky closed .. hooe that helps you . G/luck ??.. Tony
Apr 19, 2017 | Whirlpool Refrigerators
Freezer on my whirlpool ed5ftgxkq wont frreze.. just defrosted all of a sudden today..
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Refrigerators
Whirlpool model ed5chqxkbo1 wont cool
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirlpool ARC7470AL FRIDGE FREEZER
you have one of three problems and only one problem
the defrost timer is bad
the defrost heater is bad
the defrost thermastat is bad
only one of the above is the problem but no way to know without checking each part with and ohm meter
May 07, 2008 | Refrigerators
Kenmore Refrigerator Model #25357677791
stuck defrost timer/ thermostat. id go with both stuck because I'm looking at a diagram of your fridge now and there wired together.
i'd recommend changing both of them.
hope to be of any assistance.
Apr 26, 2008 | Refrigerators
Refrigerators Logo
219 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
