Question about Philips FWC788 CD Shelf System
Philips FWC788/Disk Not Finalized Error Message!
Hello! I have had this sysytem for about 2 years. I am listening to the CD player today and all of a sudden when I change the CD, I get the message "Disk Not Finalized for every Cd I insert. Even brand new ones. PLEASE HELP!!!!!!!!!!
  • Anonymous Dec 27, 2008
    My cds dont play getting the same error message "disk not finalized"-used disk cleaner but still getting same error message not able to play disc cleaner cd.
    Thanks, Patt
    Novelist:
    Champion:
  • 277 Answers
The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Posted on Dec 04, 2005
SOURCE:
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Can't play CD's
Lense cleaning discs are available at many electronics retail store and websites.
Jun 15, 2008 | Philips FWC399 CD Shelf System
Cannot unfinalize the CD RW disc.... I press ENTER to unfinalize but when the countdown arrives at 53sec it switches off and the disc remains finalized - please help !
clean the cdr with a cd cleaner if that doest work u mite need a new cdr. hard 2 find cdrs that work 4 philips am looking i got a cdr 788
Mar 15, 2011 | Philips CDR796 2-Disc CD Recorder
Hi, my cd player will not read cd's. It will read disc not finalized. We have a philips cd player. I'm not sure where to find the model number. It is a 3 disc changer. I read about cleaning the eye, but I...
you need to purchase a laser disk cleaner to clean the laser they are available from almost all electronics retail outlets
here is a picture of one
have a great day
please rate this advice if it helped
Jan 03, 2011 | Philips Audio Players & Recorders
Hello, I have a Philips Compact Disc Player CD 753. For all CDs I try to listen to, "Disc not finlaized" appears on the screen whereas I know that those Cds are finalized. I already cleaned all Cds and...
Most problems like that are caused by a dirty lens on the player itself. If cleaning doesn't solve it there could be damage to the lens or some other kind of fault.
Jan 05, 2018 | Philips CD753 CD Player
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I burned & finalized a DVD+RW with family
while u were burnin the disc which format of disc u selected.......if u selected data disc then some of the dvd players will not read those dvds..............u should not select data disc .................instead there r some options to burn the disc....it depends on which version of nero or the cd burner product u use
Oct 14, 2009 | Sylvania Televison & Video
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
Message of an Error
error 6 means that a disc is loaded upside down.
eject the disk and reload it properly
if that isnt working, your CD player is mal-functioning and you should consult Clarion for help
J
Mar 12, 2008 | Clarion DXZ845MC CD Player
Recorded finalized CD's will not play on standard CD player
Are you using the same brand of discs you used to? Do they palyback on the machine in both the record and the playback deck? Do your old cdr's you recorded still play in the standard cd player? You can try the diagnostics - hold down the 'play' and 'fwd' keys on the record side as you power it on.
Oct 31, 2007 | Philips CDR778 2-Disc CD Recorder
Philips FWC788 CD Shelf System Logo
1,411 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
