Question about WeatherWorks CH3001 Oil Filled Radiator Heater
Oil filled Heater will not turn on and heat.
Nothing happens when we turn the heater on. The on/off lights do not light up and the heater never heats up. Our power source has been checked and is fine. We used this heater all last year and it worked great.
    Novelist:
    Champion:
  • 277 Answers
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Posted on Dec 04, 2005
I have been using my heater in the garage to prevent my water pipes from freezing. It just quit working today. The lights do not light and it will not heat any longer. What happened and what can I do to...
Have you checked the circuit breaker or fuse for the circuit that your heater is on? It's possible that you had something else come on that, combined with the current draw of your heater, popped the breaker. If that turns out to be the case, turn the heater switch from high to medium or from medium to low so that you're drawing less current.
Feb 24, 2015 | Comfort Zone CZ7007 Oil Filled Electric...
Oil filled heater won't heat up. It does turn on and the light illuminates but no heat. I't been in basement for the summer.
Could be that the thermostat is disconnecting because it senses too warm.
Plug the heater to the wall, turn on the switches.
Turn the thermostat knob all the way to min. It should make a click sound and the heater should not get warm.
Turn the thermostat knob all the way to max. It should make a click sound and the heater should get warm.
If the heater is still not warming up and/or you don't hear clicks, then the heater has bigger a problem.
With the cheap prices of the heaters, it is not worth trying to have an electrician check it out. Just buy a new one.
Oct 18, 2013 | Midea Oil Filled Indoor Heater - USA, INC
My Comfort Zone Oil filled CZ7007J Radiator is not heating, it was working just fine when I turned it off, but when I turned it back on, no lights, no heat, like it's getting no power. Bought it
doubt there is any warranty being made in 2010 but they do have a heating element very similar to an electric water heater .I know of no repair shops that work on them.nor where you might find an element . SORRY Personally I found these oil filed heaters cost more to operate than the ceramic. types
Dec 30, 2017 | Comfort Zone CZ7007 Oil Filled Electric...
Heater does not heat when turned on. indicator light stays red
check oil overtemp senser or heating element, some of the newer ones have a circuit board with default codes, check for codes,unplug, plug back in and see if it works
Jan 30, 2010 | Honeywell HZ-710 Oil Filled Radiator...
All of a sudden the heater is not heating up. The
make sure the thermostat dial is not turned all the way down. The red rotary dial, set it to 6.
Dec 15, 2009 | Honeywell HZ-680 Oil Filled Radiator...
If i turn the switches on they light up but nothing happens! no heating up or nothing not a sound. does it take a while for it to warm? is i suppose to be silent? or should i be able to hear it start up?
very little sound and it does take quite a while to heat up .. you should feel warmth in 15 min .. if it doesnt heat at all then there might be an open "over temperature" fuse inside ... one of the good things about this heater is that its so quiet ..
Nov 23, 2009 | Lakewood (5500) Oil Filled Radiator Heater
Left Heater switched on over night, oil radiator de longhi dragon
1st, check the electrical cord plug; because of the hielectric demand, thesaes plugs overheat and form a burn coating on the prongs that stops the hilevel of electric but allows a small level ofalaectric that still lights the lights but no power for heat.
2nd, the thermostat is not making contact: it is a bi-metal contactor that sometimes burns or loses its strength and no matter where you turn it it wont work. You can simply cross the terminals of the thermostat to see if you get electric flowing (you have to open the oen housing to do this.
3rd, the element could be burned-out or (as often happens) the connection to the heat element burns-off. Again, you need to open the end housing and look, or take it to a small appliance repair place.
Oct 11, 2009 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Won't heat
Try calling delonghi america at 1800 322 3848
Dec 14, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
WeatherWorks CH3001 Oil Filled Radiator Heater Logo
1,014 people viewed this question
Top WeatherWorks Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a WeatherWorks Heating and Cooling Expert? Answer questions, earn points and help others
