Sony STR-K670P I left my amp on for a couple of days while not home. When i returned home the amp, and main display aren't working. Only the small orange "afd" light is illuminated. Help...
  • 1,512 Answers
Hi david880
First trick to try is turning the amp off completely by disconnecting it at the wall for 10 mins. Then reconnect and see what happens. You may have had a power flip that has corrupted the program counter in the microprocessor stages of the amp. powering it down completely will reset the amp and processor, hopefully solving your problem. If it does not, please get straight back to me here before you rate this solution(suggestion at this point)and we can talk further. .
Posted on Sep 06, 2008
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
How do connect Sony audio receiverstr-k670p to Samsung smart tv?
Both should have an optical audio jack. Easiest way to hook the two together
Jul 28, 2015 | Sony Str-k670p
How do I program a Sony STR-K670P Reciever to a Sony Universally Remote RM-VZ220 Sears says it's compatible but because it's a reciever not a DVD player I don't know how to program it it because it...
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
May 23, 2014 | Televison & Video
Plugged 120v home theater into 220v outlet
No. I wouldn't suggest trying that. It would be hazardous to your health and I seriously doubt you would be able to troubleshoot it. My question is, the power cords are nothing alike between 220 and 120 volts. How did you even plug it in? For more information, or should you have any further questions, please visit my website at You may contact me directly through the website. Thank you.
Dec 18, 2013 | Sony Audio Players & Recorders
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
Sony Receiver STR-DE310 flashing "PROTECT'
Replacing ouput transistors and probably a couple of resistors is best left up to a repair shop. The entire main board needs to be removed to access the solder side of the board, many screws and several connectors.
Jan 21, 2010 | Sony STR-DE310
Sony STR-K670P Surround Reciever. No output from Front L or R channels. Checked Speakers OK. Also no output from headphone jack. Center, Rear L,R and Sub all OK.
This is a common problem that a lot of people have with this system. The problem is in the connection of the Left and Right Speakers to the receiver. I had this problem too.
What you need to do is actually open up the receiver using a screwdriver. Once it is opened up you will see a circuit board and lots of wires. Look for the red and blue wire that should be pretty easily visible. Cut each one, then strip the ends some, and reattach the ends but to the opposite color- make sure to solder it as well. On some models they messed up the connections and it got switched. Once you do this, the left and right speakers should work great. Hope this helped!!
Oct 19, 2009 | Sony Audio Players & Recorders
Sony STR-DE525 Left Rear channel not working
Most likely the amp for that channel is defective. If memory serves me correctly, there is a small amp chip mounted on the heatsink that is for both the left and right rear. I would change that first. It should have about 5-7 pins.
Nov 30, 2008 | Audio Players & Recorders
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
236 people viewed this question
