Question about Samsung Modem Configuration Software (413115)
Hands free feature
Every time I pair my Samsung SGH-D880 with my car GPS, Garmin Nuvi, the mobile reboots itself, and does this again during making any call.
Also the data on the phone book is not correctly shown on the Garmin GPS.
Ps: Never been through this when I was using Motorolla mobile
Thanks
I had the same problem : seems that the reason for this, is a double (or multiple) input in the phonebook with the same name : whenever the phone tries to send the contents of the phonebook to the car GPS, it detects the "double" (or multiple) input(s) and does not know what to do with it. Thus the phone blocks ("hangs") and reboots itself. A simple remedy for this : just remove the double input(s) from the phonebook and the problem will be solved.
Posted on May 23, 2009
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi710 phone book detail does not match phone contacts
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
Jan 26, 2010 | Garmin Nuvi 265W GPS Receiver
Just got nuvi 765T garmin and tried the hands free last night, but I cannot hear the people calling me through my garmin
try a software up grade fro www.garmin.com as 7 series has some soft ware updates , some phones as a pain as software is not fully comapatable, a software fix from your phone supplier may help, email garmin if your phone is compatable
Dec 26, 2009 | Garmin nuvi 765T GPS Receiver
Garmin nuvi 265 WT CAN'T PAIR BLUE TOOTH WITH SAMSUNG CELL PHONE
I had the same problem but I think I fixed it by NOT sharing my phonebook.
Mar 19, 2009 | Garmin nuvi 265 Car GPS Receiver
Blackberry 8320 address book unable to import to Garmin Nuvi 265TW AT the start of pairing it did import it but once blacberry out of connection  from garmin or disabled, when enabled pairing address is...
The address books may not be compatible with each other regardless of pairing or not. Best bet is to check on garmin.com in the support section. If it isn't they you can use the dial up on the GPS as well as any other enhanced features that require bluetooth services.
Feb 13, 2009 | GPS
Garmin bluetooth won't disconnect call
Solution below works for NUVI660 as well; ignore everything after step 6 but DO reboot and delete previously existing connections.
good luck
All,
I was having the same problem with my Curve and Nuvi 680. What has fixed this for me is downgrading the Bluetooth firmware version on the Nuvi itself. I was running version 3.0 (you can check your version by going to Settings -> System -> About on the Nuvi) -- I had success after downgrading to version 2.4.
It's a bit of a convoluted process, but here is the procedure I followed:
1. Download the old Nuvi BT firmware from the Garmin Italy website:
http://www.garmin.it/files/FileBluetooth.zip
2. Connect your Nuvi to your PC.
3. Go into the X:GarminRemoteSW and look for a file called 006B055301.GCD (where X: is your Nuvi drive)
4. Back up that file to your
computer, and delete it from the Nuvi.
5. Extract the file in the zip downloaded in step 1 to the X:GarminRemoteSW directory
6. Disconnect your Nuvi from your computer, and let it
reboot
7. Click on "View Map," then touch the "Speed" in the lower left corner.
8. You should have the "Dashboard" view up. Touch and hold the "Moving Average" box for ~15 seconds until the diagnostic screen appears.
9. Press the "next" button until you arrive at the "Bluetooth Status" screen (5-6 screens in)
10. Click "Updt PR" and then click "Yes"
11. Reboot the Nuvi, delete the existing bluetooth pairing, and attempt to re-pair with your BlackBerry.
Seems to work perfectly now -- please let me know if you have any questions. Good luck!
Feb 11, 2009 | Garmin nuvi 265 Car GPS Receiver
Bluetooth
GB,
The phone information isn't stored in your Nuvi. Each time it pairs with your phone the call, phonebook and other information is retrieved by the GPS.
To manage your phone activity you have to do it within the cell phone itself. Clear your messages and the next time you pair with the Nuvi you'll notice everything is gone.
Cheers
Nov 22, 2008 | Garmin Nuvi 660 GPS Receiver
Dont have cell phone icon anymore on nuvi 360
Have you tried to re-pair it with your phone? What does the bluetooth firmware version show up as on your Nuvi? If it says 0.0, you need to reflash the bluetooth firmware. You can find the firmware version by selecting the wrench icon, then sekect the gear symbol and then select "About". Use Garmin's webupdater and connect your Nuvi to the PC and let the webupdater reflash yoour Nuvi. Garmin just updated the bluetooth firmware on November of 08 to v3.4 so you would want to do it anyway. When you reflash, you have to repair the phone to the Nuvi because the reflash erases your phone setup.
- Jim
Nov 16, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Computers & Internet Logo
135 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
