Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Failed resistor Tv would not turn on. Got three blinking lights. removed the back and found a resistor that was discoloured. Is this the problem?
  • 4 more comments
  • coolmike711 Sep 06, 2008
    Thanks Slinteriors.
    One more question, If I leave the tv unplugged for 48 hours would that be enough time so I can work on the board without being shocked.
    I want to remove the board. How do I discharge the power so I don't get shocked.
  • coolmike711 Sep 07, 2008
    Slinteriors,
    I replaced the resistor first and it burned again. The I replaced the IC's and the resistor and the same resistor burned again.
    What now...
    The other five read the same, I figure they are good. The burnt one has no reading.
    Yeah, I am about to do that. We will see what happens.
  • coolmike711 Sep 09, 2008
    What is the convergence yoke and where is it?
  • Panasonic Master
  • 8,617 Answers
Those are the convergence feed resistors. # blinks on a panasonic means convergence IC failure. You will need to replace the two stk392-110 convergence ICs and the six resistors. You can get replacement ICs and resistors at the following link.
http://servicemanuals.vstore.ca/
Posted on Sep 06, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Sep 06, 2008
    first off leave it unplugged for at least a half hour, then when you remove the HV lead just ground the end for a few seconds to be safe but most dangerous voltages will drain done after a half hr except the CRTs but your not going to be unhooking them
  • Sonny Berry
    Sonny Berry Sep 07, 2008
    there are six of those resistors which are all the same rating unsolder one side of the resistors and lift it out of circuit and check the resistance of all six resistors
  • Sonny Berry
    If you have replaced the ICs and resistor and that one resistor keeps burning you will need to trace that circuit with the schematics to see what other components are on that one line with the resistor and one of those components have to be shorted or open. Possibly a capacitor or diode itcould also be the convergence yoke for that line.
  • Sonny Berry
    Sonny Berry Sep 09, 2008
    the convergence yoke are the small rings on the neck of the picture tubes closet to the circuit board on the end.
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
TV wont turn on but it does make the clicking noise as it is trying to do so, the power light flashes three times and extinguishes
The three blinks is an error code indicating that the convergence has failed. You can get the PT47WX49 convergence repair kit from www.tvrepairworld.com whih has the 2 Convergence ICs and The 6 low ohm resistors plus the CD with repair instructions.
Aug 31, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-61hx42, turned on tv and the power light blinks three times in a continus pattern. I assume this is a power supply problem, can you tell me which componet is blown?
The three blink error code is the error for failed convergence ICs and the low ohm resiustors. You can get the convergence repair kit for your model from www.tvrepairworld.com which has the 2 ICs and the 6 low ohm resistors plus the kit contains the CD with detailed repair instructions.
Jul 21, 2011 | Panasonic PT-61HX42 61" Rear Projection...
I have a panasonic pt-47wx42 projection monitor. It will not turn on and the red light next to the power button blinks three times
The 3 blink error is caused by failed convergence ICs and the six 2.2 ohm resistors. Installing the convergence repair kit for your model should solve the issue. The kit is available from www.tvrepairworld.com the kit contains the 2 ICs with heat sink paste, the 6 resistors and the cd with instructions
Jul 11, 2011 | Panasonic PT-51HX42 51" Rear Projection...
What does three blinking red lights mean on the power, when my tv just turned off on its own no warning?
The three blinks is indicating that the convergence circuits have shorted and have shut the set down. You will need to replace the two Ics and the 6 resistors. You can get the repair kit for your model which contains the two Ics the resistors and the CD with repair instructions from www.tvrepairworld.com
Jul 05, 2011 | Panasonic PT-47WX49 47" Rear Projection...
My rear projection tv just failed me by turning off. The picture seemed fine, no convergence, but it turned off while the power indicator blinks three times. Have read similar posts, but did not have the...
Yes, the three blinks is short protection. If one or more of the 2.2 ohm blue resistors is white in the middle one of the STK-392-110 chips got it.
I may be the one whose post you saw. I have start to finish step by step instructions for this repair in this set.
I can also tell you the best place to get them and the instructions tell you everything you will need and how to do the repair in the best way.
They are based on the fact that I have fixed hundreds of these sets with the same problem you have.
SD TECH
May 19, 2010 | Panasonic PT-53WX52 53" Rear Projection...
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
TV will not turn on Yellow power ind. Light blinks three times...
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
TV turned off and now the power light blinks three times
Very common problem. 3 blinks means the convergence circuit has failed . Heres a link to the repair kit for your model which contains both convergence IC and the feed resistors and the kit has step by step instructions with pictures so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
