Question about Panasonic Microwave Ovens
I have a Panasonic Microwave
I have a Panasonis Microwave Oven Model No NN9507 Serial No A68220070which fails to operate on Microwave. The convector oven is OK. I am a registered Electrician and would appreciate a service manual or similiar
  • Leslie Morris
    Leslie Morris Sep 06, 2008
    Hi Thank you for your speedy reply.
    1. There are no unusual noises
    2. The light and turntable are normal
    3 Everything seems normal but, no heating takes place on microwave setting.
    4. Convection qven is working OK.
  • William Miller
    William Miller May 11, 2010
    What do you mean by "fails to operate on Microwave"?
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
  • Panasonic Master
  • 9,098 Answers
With these symptoms, the most likely suspects are a loose or corroded connection on the FAQ terminal of the magnetron, a bad magnetron, a shorted high voltage rectifier diode (which would cause a louder noise).
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
You can order Panasonic parts here.
We\'re happy to help you with free advice and we\'d appreciate your thoughtful rating of our answer.
Posted on Sep 07, 2008
Sharp Microwave Model nn 9507 Diagram
Panasonic NN9507?
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Here are some links you or someone you know can use for test help, but read the safety warnings first:
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jun 08, 2013 | Microwave Ovens
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Mar 12, 2012 | Panasonic Microwave Ovens
Where can I get a manual for a panasonic microwave convection oven serial number 863170033 model number NN-2909 manufactured in June 1993. has the owner's manual for sale: ; scroll through the parts list in the All Parts section or limit your search to the Microwave documents in the box on the left. is the direct link.
Unfortunately, I do not see the NN-2909 listed at any other site.
I hope this helps.
May 28, 2011 | Smeg FMC24 850 Watts Convection /...
Panasonic dimension 4 microwave/convection oven Micvrowave part of oven not working, convection oven/grill fine. Is it a problem with the magnetron? Is there some form of internal fuse?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | Panasonic NN-C980 Convection/Microwave...
Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link if this helps please rate how i did. thanks for you question.
Mar 18, 2009 | Microwave Ovens
Need owners manual
I am assuming this is a Panasonic model. I was just at their website, and I believe they had your model listed where you could download the manual. Go to appliances.
Jan 16, 2009 | Microwave Ovens
Panasonic Microwave Oven Stops After 15 seconds - Never Heats
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Operates for 3 seconds on microwave then stops
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 15, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
52 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
