Question about Refrigerators
Insufficient cooling The refrigerator does not cool. The boiler does work on propane and electric. The on/off buttons and thermostat buttons are all working normally.
  • 2 more comments
  • dlineberrys Sep 06, 2008
    Thanks that is what we feared. The boiler does work because it does get hot to the touch. The absorber vessel and coils are cold. We also saw yellow powder which some are saying is an indication that the chemical has leaked out. We are thinking about replacing our absorption refrigerator with a standard refrigerator. Does anyone know if it is safe to use a standard refrigerator in an RV?
    Thanks for confirming it.....We found a standard refrigerator, Magic Chef
    10 Cu. Ft. Compact Two Door Refrigerator which fits the dimensions of our Norcold 9182 exactly. It is so much more cost effective for us at $350.00 with tax vs $1500.00 with tax. Not being able to us the gas to dry camp would be a bummer as most NPs have specified hours for generator use. On the other hand this represents about 1-3% of our total use since we are full-time RVers. Some have said that the constant "plugging and unplugging" of travel would damage the standard refrigerator's compressor....that they need to be plugged in continueally. Is this true?
    We are not as concerned about it tipping. It will be fitting very flush into the same area our RV refrigerator was. The sizes are almost exactly the same. It will be fitted to the ceiling and on each side. It would sit on a platform made for the current RV refrigerator. So the only motion would be during a right turn....for it to want to tip out into the rig...but being braced by the ceiling...I don't think it will be going anywhere. As far as being fulltimers we are parked for at least 3 days at a time to sometimes months at a time. It just depends on our pace - which these days due to the cost of gas is not so fast! Is there any way on travel day to safely turn off the refrigerator's compressor before we unplug from electrical power for travel?
  • dlineberrys Sep 08, 2008
    Well we have been on the RV forums and have found many who have done this conversion. Despite the drawbacks, we have decided to go for it. If it poops out down the road, then it was a good experiment and not too costly of one.
    Mainly the issue with this model from what I have been reading, is making sure that it gets even ventilation. The side of it are what radiate heat, not the top or back. Of course this refrigerator warns not to use it in RVs or with inverters. Many are not following those directions. LOL. It did also say that you could not use this model in a garage either. I KNOW NO ONE IS FOLLOWING THAT RULE. lol. So far we did purchase it. We powered it up and it runs like a charm.
    The big drawback on RV refrigerators is that they just can't keep up with the heat in the summer. We work and full-time. We never know where we might be. We did a summer in Vegas two years ago, which may have helped the death of our Norcold along sooner rather than later. It is a pain to always have to hurry to get out what you need from the RV frig. Fumble around and it is a cause of cursing. LOL. That is why we are willing to "gamble" on this idea of going residential. It would be so nice to actually be able to eat ice cream again!
    Scholar:
  • 141 Answers
Sounds like an absoption fridge with a blockage or leak.
Just to be sure.... How do you know the boiler is working? If it is hot to the touch, then is is working, otherwise it is not.
If it is working (hot to the touch), then it should be the same temperature to the touch as the fridge coils. If the coils are much cooler or much warmer than the burner tube, then you have either a leakage or a blockage. Either way, you need to replace either your cooling unit or entire fridge.
If the boiler tube is not hot when the fridge is turned on, then you have a blown fuse or faulty control board. Or you have no power going to the fridge.... :)
Posted on Sep 06, 2008
  • 3 more comments
  • Steve Froese
    Steve Froese Sep 06, 2008
    The yellow powder is the calcium chromate that is mixed in with the anhydrous ammonia. This is a 100% indication that your ammonia has leaked out.
    I am a certified RV technician, so I can answer this question for you. It is safe to use a conventional fridge in an RV, but since they run on AC voltage, it won't work unless you are plugged in or running off generator power. Also, they are difficult to secure for travel unless you use a very small one. Finally, they are not made for being bounced down the road, and also the doors will constantly open unless you rig some kind of latch. Given all this, plus the fact they only run on AC, causes most people to forego this idea and opt for the more expensive RV ones. It's worth it in the end, believe me!
  • Steve Froese
    Yes, that is certainly a concern. The compressor could easily be stressed to failure in this case, which is something I forgot to mention in my thread. It is the same idea as when you start and stop the generator with the roof air running. You are doing serious damage to both the genset and the AC compressor.
    However, if you are fulltimers, I would say the compressor will be running most of the time, wouldn't you say? Plus if it does fail, you can buy 3 of them before you have paid the $1,500 for an RV one.
    In summary, I would recommend against a domestic fridge, but if you are fulltimers and the thing won't get unplugged or moved much, you may be okay. My only other concern is the tendency for it to move or TIP when you do drive around
  • Steve Froese
    Sorry, I have a few cobwebs. When you said you were fulltimers for some reason I was thinking you might reside in a park fulltime, but of course that is likely not the case....
    Sorry to be a little wishy-washy, but here is my best advice on this topic.
    If you are fulltimers and you are moving from place to place most of the time, do not get the domestic fridge, stick with the RV fridge. Here are the reasons:
    - When you drive, you are risking the safety of those in the coach from fridge movement, and you are also risking damage to the fridge, mainly the compressor
    -Every time you disconnect and reconnect your shore power, the compressor gets slightly stressed. Eventually this will likely cause failure.
    -The fridge does not have the ability to run except on shore or generator power. This is normally okay as you are driving down the road during the day, but you may not have shore power when you are stopped overnight (like Walmart! :))
    Sometimes it is cheaper to have the cooling unit replaced than to replace the whole fridge. You should get some price quotes from different RV dealerships. If I was closer, I'd be happy to do it, but I'm in Vancouver, Canada. You are likely somewhere far away :(
  • Steve Froese
    Steve Froese Sep 07, 2008
    Let me know what you decide to do. I am interested
  • Steve Froese
    Steve Froese Sep 08, 2008
    Sound like you thought it through.... Good, sounds like you made the right decision for you.
    regarding the heat. Hot temperature certainly adversely affect the efficiency of absorption refrigerators, it should not cause premature failure. The only real issue with heat is that the temperature difference between the coils and the ambient temperature becomes smaller, which reduces the ability for the coils to shed heat...
    When I was working as an RV tech, I was always happy to have customers who were either educated enough or did their homework enough so that I could discuss their problem with them on a reasonably technical level. You fall into this category, good for you!
Utica furnace hot water system problem
Check the heat Antisapator on the thermostat, or replace the thermostat.
Nov 13, 2013 | Heating & Cooling
My dometic rv refridgerator is not cooling at all on propane or electric?
disconnect thermistor let run if ok replace if not replace board
Dec 23, 2012 | Dometic Refrigerators
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
My Dometic RM2652 in my camper isn't getting cool enough when it's set on electricity. It feels cool, but not cold. The ice in my freezer turned to water, but it was still cold. The refrigerator section is...
Sounds like maybe your element for Heating when on hydro may be faulty. A voltage check at spades on board connected to element will confirm. If power to element but no heat felt at element should confirm it's faulty. Remember, if stack is already hot from propane, element will also feel hot, so it has to be out or fridge cooled down at back first.(off)
Apr 20, 2011 | Dometic RM2652 Refrigerator
Won't cool on propane. Thermostat doesn't change the flame at all. After "burping" it several times without success, we have removed the thermostat, hooked it up to electric - which is fine for now in...
check the line from the inlet valve to the thermostat.Mine was 1/3 plugged from new,poor workmanship after cutting the line ,no one cleaned the inside of the pipe
Aug 04, 2010 | Explorer Appliances GRQ15 Top Freezer...
Kenmore 61042 fan motor replacement
hi! you mean there is ice on the part of evaporator or some in other part? its normally cool your refrigerator inside part.If ice is present your fan have insufficient air neede to frost free your evaporator its not the same with the origina you replace,beside your thermostat is not working have check this one.
Nov 23, 2008 | Kenmore 61042 Top Freezer Refrigerator
RM 2401 1990 Bigfoot RV fridge not cold
you ahould put poop in it it work for me
Jul 24, 2008 | Refrigerators
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
