Hi
Its mean you battery age is over, so please go to nearest nokia service center and get the new battery for your mobile.
Thank
Remove the battery and check the voltage on the battery using a multimeter. Also check the voltage on the charger unit. If both the readings are good then clean the terminals and charge. Check the voltage at the terminal of the battery in the phone. If this is absent or low then there is fault in the motherboard.
