Computers & Internet Logo
Posted on Aug 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Am unable to charge my mobile 6234 with pc through usb cable.
Level 3:
  • Master 17,130 Answers
  • Posted on Aug 16, 2011
Master
Level 3:
Answers
17130
Questions
0
Helped
3633069
Points
52372
Check with another PC to confirm the USB port. If there is no charging then there is fault in the cord or the phone harware.
Check with another cord,check the phone if the cord was tested with another phone to be working good.
RESTRICTION & MASTER CODE FOR NOKIA 6234. IMEI-359395003537405
Hi, To which network has your Nokia 6234 been locked to? The safest and easiest way to unlock a mobile phone is to unlock using unlock code. An unlock code for a Nokia mobile phone can be obtained either from the respective network provider or from any trusted vendor online. for example, An accurate unlock code for a Nokia 6234 can be obtained from www.simpleunlocking.com/nokia-6234/rs16wp9/ at affordable cost. This site provides accurate unlock codes for over thousands of mobile models at low cost with easy unlocking instructions.
UNLOCKING STEPS FOR NOKIA 6234
1 - Switch on your Nokia 6234 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6234.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6234 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6234 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6234
The master reset for a Nokia 6234 can be done through any Nokia Priority dealer.
Oct 22, 2012 • Cell Phones
Nokia6234 hard reset
The Nokia 6234 cannot be unlocked because it is a 'BB5' Model. This restricts the phone and cannot be unlocked via code or cable for free. The Only way this phone can be unlocked is if you visit your mobile service provider, and request an unlock or by box, so your local mobile unlock shop should be able to do it.
2helpful
My motorola rokr e8 wont charge with usb cable on my computer
hi...
To charge your mobile with usb cable you should install a driver called as mobile phone usb driver ,if you install it you can charge your mobile through PC.
If still it doesnt charges then install the PC CHARGING DRIVER.
I will give you the website which contains the driver and the instruction below it to install the driver so that you can charge your mobile by usb
website : http://www.motorola.com/consumers/v/index.jsp?vgnextoid=3fd11e8c04021210VgnVCM1000008406b00aRCRD
thanx
Unable to connect my Sony Ericsson W580i Mobile to a PC
hi,
the problem is with the usb cable. try the same with different cable. if the same problem happens with the different cable then there is problem with your phone itself.
L7 unable to charge
All cellphone run on Lithium Ion batteries. These batteries, by nature(physics) have a max charged voltage of 3.4 to 4VDC. So, of your charger, or USB cable, has less than about 5 VDC, then either charger is defective, USB cable(if charging from PC USB port) is not a FULL USB(has data leads only wire, 5V power wire not carried through, PC does not supply 5V power to USB because it is turned off by a PC setting option, or a non-powering USB Hub or other device is in series with PC and Phone.
Are you sure you have identified the GND wire correctly? Measurements must all be made with one lead of your VoltMeter referenced to GND. Another consideration, some Windows Mobile phones will not charge off the USB cable unless the latest version of WM ActiveSync or Mobile Device software is loaded and running on the PC. These WM phones also will not charge from just any AC USB generic charger. Charger has to be for that particular phone, or phone manufacture, to be 'recognized' before provideing charge.
The
8helpful
3answers
O2 xda 2 mini pocket pc usb connection problem
how i get my o2 xda ii mini drivers?
1helpful
Nokia 6234 Charging circuit
No, take the battery out and bring it to an auto part store and they can test it.
Jun 18, 2008 • Nokia 6230
1helpful
Charge by usb cable
When we connect the phone to PC it automatically start charging but after 5 mins it stops its because we do not take any kind of action i.e. if you will send some files to phone or will operate phone from PC it will keep charging otherwise as you have said it will stop.
5answers
Data cable
I think you will B OK, the Cable you use is BOTH comm's and batt charge the msg ya get is because batt charging is finishd.
Grand Canyon Tech
Grand Canyon Tech
