Question about Fisher and Paykel 23 in. DS603H W Built-in Dishwasher
Fisher&paykel d603 dishwasher
Runs continously shows up F1 on screen with spanner under it
  • rusty-nai306 Oct 15, 2008
    thanks for the help it has shown i have a futher problem
  • bikersfriend May 08, 2009
    I have the same problem as described in Best solution posted by resolver on 18th. October, 2008 but there is no water in the bottom of the dishwasher. could this be a faulty flood sensor switch? If so where is it located in the dishwasher? Is it the circuit board in the bottom of the dishwasher? My dishwasher is a Fisher & Paykel model no.603
    thanks Ken
Disconnet Dishwasher, Remove lower dishdraw, soak up excess water with a towel, use a hairdryer to dry water especially under grey plastic cover. Then check seal on either dishdraw and make sure they are not kinked or leaking as this has most likely caused the problem. Power up problem should be resolved. Don't leave dishdraw unattended till you validate problem definately fixed.
Posted on Oct 15, 2008
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Washer keeps blinking with a spanner and F1 function
F1 is a flood error. Below is a link to a video that you can download that shows you how to repair your dishwasher.
Good Luck
Feb 25, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 flashing with a spanner showing
F1 code indicates a leak,you will find the water under bottom drawer.Might be the lid probably not sealing well. You have to seal it well properly to fix this error in your dishwasher.
Thank u !!
Jun 17, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
The unit flashes F1 with a spanner sign showing on both drawers
Refer your problem with fisher and paykel DD603 dishwasher. Please clarify how are you able to assess the motor is driving in top gear. Which lights are flashing?
Is this problem in both drawers or just one?
May 30, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
HI my fiser and paykel dishwasher is flashing f1 and is showing a spanner whay does this mean
The F1 error means a flood switch has been activated in the drawer. The spanner means you need to call a technician.
The possible causes are that the solenoid that controls the water inlet does not shut off or the sensor that detects the water level is not working. Also it is possible the water pressure is not optimum for the setting on your unit.
Nov 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
We have the Q 2 drawer dishwasher stopped working.
the f1 is the flood sensor....a leak has accured....either a dish to larger or lid motor has failed. will need to remove bottom drawer and soak up water and then let air dry for a day or two....turn off the breaker this will keep it from beeping and running the pumps....after drying unit will run, but need to watch the dishes you put in drawers.
Jun 30, 2009 | Fisher and Paykel DD605HSS 23 in. Built-in...
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Fisher and Paykel 23 in. DS603H W Built-in Dishwasher Logo
628 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
