My router is not responding with my computer - Computers & Internet
    Scholar:
  • 141 Answers
If the router has lights, then check your network cables.
Posted on Sep 06, 2008
My computer says the Proxy server isnt responding how can I fix this?
Yes proxy server not responding is most common problem :
Go to Tools > Internet Options > Connections. If you are on a LAN, click "LAN settings" and make sure your firewall settings aren't blocking your web access. if not solved than go to your router setting page http://support.netgear.com/for_home/default.aspx and need any
technical assistance for set-up DNS setting http://www.techsupportrouter.com/
May 21, 2014 | NetGear RangeMax NEXT WNR834B Wireless...
DNS server not responding on WRT54GL Linksys router
You are looking for DHCP server. It provides the IPs addresses for devices to connect. DNS resolves the IP into a name. Not really required unless you are setting up a virtual server, or the special setup.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
I have an office netwrk installed through a wireless router and i wish to add 3 computers using a D link fast ethernet switch, hw can i configure my computers through the swicth... coz if i give them IP...
All you should do is connect the switch to the router, then connect the 3 computers to the switch, no further configuration required because a switch is transparent to network devices. if the computers does not obtain an IP addresses from the router (ie they get an IP address of 169.254.x.x) you may need to investigate something else like the network cables for instance, they should not exceed a maximum distance of 100 meters with proper crimping.
if this doesn't solve the problem please clarify "they seem not to respond" phrase you said
Jun 13, 2011 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Can not get my D-link router works
Find the small hole on the back or bottom of the device. Unplug everything ... with s small pin, gently depress and hold the reset button for 30 or more seconds. turn off the modem and all computers. reinstall the router. Turn on the modem ... wait ... turn on the router ... wait ... turn on your computer ...
May 15, 2010 | D-Link DIR-615 Wireless Router
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
3Com® OfficeConnect Cable/Dsl Wireless router not responding
Unless, you can try another computer to connect or there is a tiny (and I mean sometimes pinhole) reset button to push, it may have seen its last day. It has happenned to me and I picked up a little 35 dollar Belkin that worked great.
Jul 06, 2009 | 3Com OfficeConnect Wireless Router
Cannot set up D-LINK DI-704P
make sure your computer and the router is connected via a network cable.
make sure the cable is in working order.
check if your network adapter has the proper driver and is updated.
try pinging the router from your computer and see if it there is a response.
there are a million reasons why a computer would not respond to the router. please elaborate more about your problem so i can help you further.
please provide information on what are you trying to achieve and what are the steps you have taken so far and what is the result of your efforts.
Jan 28, 2008 | Computers & Internet
CISCO 2800 router interface stop responding
What kind of cable do you have connected from the DLINK to the Router? Is it an ethernet cable 3,5e,6?
Sep 13, 2007 | 3Com OfficeConnect (3CRWE454G75)...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
