Dimension c521 computer gives a post error, floppy drive 0 error and keyboard error
  • 320 Answers
The compute post tests the computer, insuring that it meets the necessary system requirements and that all hardware working properly before starting the remainder of the boot process.
1 Short Beep, Normal POST, computer is okay. No problem. 2 Short Beep, POST error....floppy drive 0 error and keyboard error........This can happen because there is something wrong with your floppy drive, something is causing your computer not to detect it or that you simply don't have one.
Check your floppy cables and connections first to ensure that they are connected properly, if they are then you may have a burned out controller on your motherboard, a bad floppy cable or drive, or your motherboard may be faulty. If you don't have one you can disable the message in your computers BIOS. To get to the BIOS screen, during boot up at the bottom of the screen it will say something like "press F2 for setup" or something along those lines. That will take you to the BIOS screen. In the settings there should be options like first boot device, second boot device, and so on... change the one that say 3.5 floppy to something else such as your CD rom.That will get rid of that message.
Keyboard error or no keyboard present shows up when your computer can't find your keyboard or there is something wrong with it. Replace with new keyboard. Thank you
Posted on Sep 06, 2008
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
I have a dell desktop dimension c521. When we try and put in a cd it wont boot up it doesnt even start spinning the cd when we puit it in. Does the hard drive need to be replaced?
Not at all.
The DVD drive works independantly and if it has a dirty lens or the laser is faulty, it will give the error you have.
Maybe you require a new DVD rom if it won't clean up.
Feb 18, 2011 | Dell Dimension C521 PC Desktop
I have a dell c521, and I'm getting a diskette 0 seek faliure ?
Restart the computer and when you see the Dell logo.Tap on the F2 key a couple of times. You would enter the system setup.
1. Use your down arrow key on the keyboard and select the option Drives
2. Hit enter to expand the same
3. using the down arrow key again select diskette drive
4. Tap the right arrow key to switch it off.
Save the same changes by tapping on the ESC key on the top left of the keyboard.
PS. In case you have a floppy drive on the computer check if the drive is empty.
Thanks for using Fixya
Jun 17, 2010 | Dell Dimension C521 PC Desktop
Diskette Drive Failure for Dimension C521
Most C521's have no floppy, if you have none:
boot to the BIOS, (F2 at boot) go to the drives setting, diskette (May be listed as floppy disk drive) set to NONE, exit and save settings
Apr 10, 2010 | Dell Dimension C521 PC Desktop
I have a dimension c521 dell desktop and I cant boot the system it says keyboard failure and it have only usb connections.. I tried few different keyboards but same story pls help me
There must be a PS2 connector for a keyboard. Use this and enter in the bios and change the error reporting at keyboard missing to none.
Feb 21, 2010 | Dell Dimension C521 PC Desktop
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Dell Internal / External USB Floppy Drive 1.44Mb *NEW* is this suitable to use as a external floppy disk drive for Dell Dimension C521 computer
Any USB external Floppy drive will work with any computer with a USB port, but if you have Windows 98 you will need an USB driver.
Jul 29, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
Boot into the bios by pushing F2 when the computer is just turning on.
Look for the ability to disable your floppy drive.
Save changes and reboot.
May 06, 2009 | Dell Dimension C521 PC Desktop
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
