Question about Whirlpool GHW9400 Duet Washer
Whirlpool duet set iphone on top of washer and the control board went nutz shows error code f 74. works fine until you get to spin cycle. it just shuts of when it gets to spin cycle
  • 15,935 Answers
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Posted on Oct 01, 2010
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool front loading duet washer stops at the rinse/spin cycle door then locks. code F31 comes up. would this have something to do with the main board?
Error F31 in your whirlpool duet washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer won't do its final drain-spin. It apparently made it through the wash cycles. I have tried re-setting, and using the drain-spin cycle several times. It does not proceed. The...
On the front of your washer below the door there is a removable panel. The screws are on the bottom of the washer. Take that panel off and inside you will find a Filter it is right in front. turn the cap counterclockwise and pull out the filter. Clean it up and reinsert it. They get full of pocket junk, hair, and coins. I warn you it smells horrid. Once you have it back together. Run a clean cycle for the machine and it should drain fine. If this doesn't work than it could be a problem with the control board.
Sep 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport will not work
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer shows error message "F 06"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jan 29, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F11 and f dl errors
I hope that you have a serivce contract or something on this unit you need a main control board f11 means that there is communication error between the 2 computer boards the fdl means that there is is door lock problem. But that is incorrect that is how you know which board has the problem the door lock is controlled by the main computer board. it's just playing tricks on you I have tried changing the door lock with those codes and it did nothing. that board tends to be alittle pricey .good luck.
Dec 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F11 code washer locks up
We've had this problem for about a yr when i finally firgured out how to correct it. the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get. How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal De
