Question about Casio FX-115ES Scientific Calculator
Weather casio FX-115ES can solve 5*5 matrix
i would like to know whether this model casio FX-115ES can solve 5 by 5 matrices and if not please suggest me which can solve it.
  • mndymtchll Apr 24, 2009
    I can't get an answer for my problem
According to the manual for the Casio FX115ES, the largest matrix it solves is a 3x3.
Posted on Sep 11, 2008
Calculate the inverse of a 4X4 matrix on fx-570ms
The Casio FX-570MS does not handle matrices. So you cannot create matrices, let alone invert them. Sorry.
The Casio FX115 ES handles matrices for up to 3X3 dimension. Create the matrix.Have its name displayed on the command line and press the [x^-1] (reciprocal ) key.
Apr 16, 2014 | Casio FX-115ES Scientific Calculator
Is fx 115ES supports matrix with complex numbers as elements..if not please suggest one...
The calculator barely handles matrices of up to 3X3. Matrices with complex coefficients are well beyond its capabilities.
Oct 13, 2013 | Casio FX-115ES Scientific Calculator
How do i multiply to 4x4 matrices using fx-991 es ?
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
How to solve 7*3 matrices on casio scientific calculator
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-119ES/991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Nov 30, 2010 | Casio FX-115ES Scientific Calculator
On which calculator can i solve 6*6 matrix
If you want to manipulate 6x6 matrices, you can use one of the CASIO Graphing calculators, such as theCFX-9850GPlus, or the FX-9750G plus.
Graphing calculators from other manufacturers can also handle such matrices. The FX-115ES can handle matrices with dimensions up to 3x3.
Nov 25, 2010 | Casio FX-115ES Scientific Calculator
How to input numbers to solve a matrix using a casio fx-115es
Press MODE 6 to get into matrix mode. Note: do this only once. If you do it again, it will erase all your matrices. Pick the matrix, set its dimension, then the calculator will put up a screen allowing you to enter/edit the matrix elements. At any time you're in matrix mode, press SHIFT 4 to bring up the matrix menu.
All this is explained in the manual beginning on page E-57. If you've misplaced the manual, you can download a copy from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
Nov 08, 2010 | Casio FX-115ES Scientific Calculator
I have a Casio fx-115ES; I have followed the manual for creating and multiplying matrices. The matrices have been simple, 2x2 for each, but it returns with "Dimension Error". Any suggestions? Thank you for...
Calculator should be in [MATRIX] MODE
Try the matrices 2X2 matrices matA [1,2,3,4] matB [5,6,7,8], Add them, subtract them, multiply them, take the square of each. If that works for these matrices, then it must be your data. Be careful with negative numbers. To enter those, you must use the change sign (-).
There is also the possibility that the instructions were misread.
Dec 14, 2009 | Casio FX-115ES Scientific Calculator
How do i solve a matric problem with a TI- 83+
You should try to use the correct heading.
Press [2nd][Matrix] right arrow to [EDIT][ENTER] to create the [A]
matrix. Exemple of a 3x3 Matrix [A].
Once the matrix [A] is created you press [2nd][MATRIX] -->[MATH]
You can add similar matrices, you can multiply matrices, subbtract them, raise a matrix to a power, extract the square root, etc...
Here are the other operations you can pefrorm on matrices. Sorry I cannot go into the detail of things;A minimun of theory is needed to be able to use the commands.
Oct 14, 2009 | Casio FX-115ES Scientific Calculator
How to do matrix multiplication on Casio 115ES?
Hello
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB
To subtract MatA-MatB
To multiply MatAxMatB
To raise a matrixe to a power 2 [x2], cube [x3]
To obtain inverse of MatA already defined MatA[x-1] [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match (see you textbook for the rules)
Read the appendix to your user manual, there are several exemples.
Hope helps
Sep 10, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
1,211 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
